NXP® i.MX 6
Computer on Module
Colibri iMX6
- Up to 2 Cortex-A9 Cores
- NXP i.MX 6DualLite, i.MX 6Solo
- 2D and 3D graphics acceleration
- HDMI 1080p video output
- Integrated OTA remote updates, device monitoring, and remote access with Torizon
- Linux OS Support included
하이라이트
Equipped with NXP i.MX 6DL and NXP i.MX 6S SoCs, the Arm Cortex-A9 cores are clocked at 1GHz for commercial temperature variants, while the industrial temperature variant has a peak frequency of 800 MHz.
With a 3D GPU, h.264 encoder and decoder and an integrated ISP, Colibri iMX6 is well suitable for multimedia. parallel camera interface and USB 2.0 cameras are options for video capture, while for displaying an output you can drive dual displays through RGB and HDMI.
Colibri iMX6 can withstand severe shock, vibration and temperature conditions. It is therefore ideal for a wide range of applications, including Industrial Automation, Medical Devices, Test and Measurement, Specialty Vehicles, Transportation Building Automation and much more.
The Colibri iMX6 is pin-compatible with the other CoMs in the Colibri family. This allows you to cost-optimize your design with no hardware redesign costs and also be future-proof. All of Toradex's Colibri Carrier Boards are compatible with the Colibri iMX6. Extensive product documentation, developer support, service partners and third-party carrier boards build our strong Colibri ecosystem.
운영 체제
Toradex offers free support and maintenance for Windows Embedded Compact and Embedded Linux on the Colibri iMX6 SoMs. This allows system designers to focus the application instead of focusing on the OS and low-level device drivers. Other OS such as QNX and Android are supported by our partners.
Windows Embedded Compact 7 and 2013 is supported on Colibri iMX6. The development and maintenance is carried out in-house by Toradex. WEC allows you to use Microsoft .Net Compact Framework and Visual Studio.
특징
CPU Name | NXP® i.MX6 |
CPU Type | Up to 2x Arm Cortex-A9 |
CPU Clock | Up to 1GHz |
Floating Point Unit | VFPv3 |
NEON | Yes |
L1 Instruction Cache | 32kB per core |
L1 Data Cache | 32kB per core |
L2 Cache | 512KB |
RAM | Up to 512MB DDR3 (64 bit) |
Flash | 4GB eMMC |
USB 2.0 | 1x Host / 1x OTG |
Ethernet | 10/100Mbit with PTP |
I2C | 3x |
SPI | 4x |
UART | 5x |
IrDA | 1x |
PWM | 4x |
GPIO | Up to 154 |
Analog Input | 4x |
SDIO/SD/MMC | 3x |
CAN | 2x |
Display Controller | Single |
Graphics Controller | Vivante GC880 |
Video Decoder | Yes |
Video Encoder | Yes |
HDMI | V1.4a 1920x1080 |
RGB | 1920 x 1200 x 24bpp |
S/PDIF In / Out | 1x / 1x |
2D Acceleration | Yes | 3D Acceleration | Yes |
Camera Parallel Interface | 2x 8/16/20 Bit |
Analog audio line in | 1x (stereo) |
Analog audio mic in | 1x (mono) |
Analog audio headphone out | 1x (stereo) |
Size | 67.6 x 36.7 x 6.2 mm |
Power Dissipation | 0.6 - 2.3 W |
Colibri iMX6 DualLite
512MB IT (WinEC)PN: 0017
A9
A9
512MB RAM
4GB eMMC FLASH
GPU
-40° to 85° C
- 샘플 수량
- 1-99
US$137.50
- 지금 구매
- 대량 수량
- 100 - 200,000
- 대량 견적 받기
512MB ITPN: 0080
A9
A9
512MB RAM
4GB eMMC FLASH
GPU
-40° to 85° C
- 샘플 수량
- 1-99
US$132.40
- 지금 구매
- 대량 수량
- 100 - 200,000
- 대량 견적 받기
512MB (WinEC)PN: 0015
A9
A9
512MB RAM
4GB eMMC FLASH
GPU
0° to 70° C
- 샘플 수량
- 1-99
US$108.75
- 지금 구매
- 대량 수량
- 100 - 200,000
- 대량 견적 받기
512MBPN: 0079
A9
A9
512MB RAM
4GB eMMC FLASH
GPU
0° to 70° C
- 샘플 수량
- 1-99
US$104.40
- 지금 구매
- 대량 수량
- 100 - 200,000
- 대량 견적 받기
Colibri iMX6 Solo
256MB (WinEC)PN: 0014
A9
256MB RAM
4GB eMMC FLASH
GPU
0° to 70° C
- 샘플 수량
- 1-99
US$91.25
- 지금 구매
- 대량 수량
- 100 - 200,000
- 대량 견적 받기
Colibri iMX6 Solo
256MBPN: 0077
A9
256MB RAM
4GB eMMC FLASH
GPU
0° to 70° C
Colibri iMX6 Solo
256MB IT (WinEC)PN: 0016
A9
256MB RAM
4GB eMMC FLASH
GPU
-40° to 85° C
- 샘플 수량
- 1-99
US$112.90
- 지금 구매
- 대량 수량
- 100 - 200,000
- 대량 견적 받기
Colibri iMX6 Solo
256MB ITPN: 0078
A9
256MB RAM
4GB eMMC FLASH
GPU
-40° to 85° C
- 샘플 수량
- 1-99
US$108.75
- 지금 구매
- 대량 수량
- 100 - 200,000
- 대량 견적 받기
최적의 SoM을 선택하는 데 도와주세요
안내해주세요Get Started
Colibri iMX6 Evaluation Kit
US$527.55
- A flexible development environment to explore the Colibri iMX6
- Colibri iMX6 DualLite 512MB
- Colibri Evaluation Board
- Carrier Board Accessory Kit
- Capacitive Touch Display 7.0” Parallel
- Capacitive Touch Display Adapter
Colibri iMX6 Evaluation Kit 2
US$348.55
- Fast prototyping and evaluation setup with Arduino and Raspberry Pi compatible pin headers
- Aster Carrier Board
캐리어 보드
SBC와 캐리어 보드에 대해 자세히 알아보기액세서리
- No special drivers required
- Atmel touch driver
생태계
Toradex Easy Installer
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your on Colibri iMX6 and choose an OS!
The Colibri iMX6 provides high-performance graphics. Toradex partners closely with leading GUI technology providers to simplify the development process and make sure that hardware resources are utilized effectively.
Qt Framework
Get started with Crank StoryboardDiSTI GL Studio
The Colibri iMX6 is ideal for critical applications where safety and reliability are key. These are also the key focus areas for DiSTI’s GL Studio.
Get started with DiSTI GL StudioTotalCross
Get started with TotalcrossIndustrial Automation
CODESYS PLC IEC 61131-3
The Colibri iMX6 is a robust SoM, and its high performance is ideal for demanding industrial automation scenarios. CODESYS allows you to develop easily customized PLCs powered by a proven, long-lived software solution.
OPC UA is a standard technology widely used in industrial automation. The stack from Matrikon is a reliable, secure and platform-independent implementation that suits the Colibri iMX6 perfectly.
Watch our webinar with BE.services로드맵
Hardware Roadmap
For details about the Toradex phase-over policy please refer to the PCN Policy Page.
- Q2'24
- Q3'24
- Q4'24
- Q1'25
- Q2'25
- In Development
- Sample Production
- Volume Production
Software Support Status
