Powered by NXP/Freescale i.MX 7: i.MX 7Solo and i.MX 7Dual Processors
Toradex Easy Installer
ARM CPU Cortex-A7 + M4
The Colibri iMX7S and Colibri iMX7D are SODIMM sized System on Module that are based on NXP/Freescale i.MX 7Solo and i.MX 7Dual SoCs respectively. The dual core ARM® Cortex®-A7 runs a peak frequency of 1GHz, while the single core ARM® Cortex®-M4 has a peak frequency of 200MHz. In Colibri iMX7S, the single core Cortex-A7 has a peak frequency of 800MHz, while the single core Cortex-M4 runs at 200MHz. Both the SoCs support asymmetric or heterogeneous multi-core processing, in which the real time applications can run on the Cortex-M4, while the user applications are taken care by Cortex-A7. The SoCs consume very low power and supports advanced security features.
Suitable for wide range of Industrial IoT Applications
The modules are ideal for building connected devices with high performance and frugal power consumption, along with advanced security features.
Easy Performance Upgrade
This module is a member of the extensive pin-compatible Colibri family. So, existing customers using any module in the Colibri family can easily migrate to Colibri iMX7.
Product Video
Latest Information on Colibri iMX7
You can find the latest information on Colibri iMX7 below.
Toradex offers free support and maintenance for Windows Embedded Compact, Embedded Linux, and FreeRTOS on the NXP i.MX 7 processor based Colibri iMX7 SoM. This allows system designers to focus the application only, instead of focusing also on the OS and low-level device drivers. Other OS such as QNX will be supported by our partners.
By virtue of the asymmetric multicore architecture of NXP i.MX 7, Colibri iMX7 is capable of running a real-time operating system such as FreeRTOS on the Cortex-M4, along with a feature-rich OS such as WinCE or Linux on the Cortex-A7. For the Cortex-M4, FreeRTOS support is offered in-house. Other OS support such as eCos, MQX, on Cortex M4 is offered by our partners.
Toradex Colibri iMX7 modules come with the Beta version of Toradex Easy Installer which offers an easy one-click installation of either Linux or Windows BSPs.
For general information about the advantages and features, check our Toradex Easy Installer page.
Get Started
Linux
Embedded Linux
Toradex carries out in-house development and maintenance of a Yocto project-compatible production-quality Embedded Linux BSP. Our extensive documentation and support makes sure your product reaches market in time. Full source code and Toradex developments are up-streamed into the mainline. Colibri iMX7 comes pre-installed with Embedded Linux.
For general information about the advantages and features, check our Embedded Linux page.
Get Started
Windows
Windows Embedded Compact 7 and 2013 are supported on Colibri iMX7 Solo 256MB and Dual 512MB. The development and maintenance is carried out in-house by Toradex. WEC allows you to use Microsoft .Net Compact Framework and Visual Studio. Microsoft is providing support and updates for Embedded Compact 2013 until year 2028.
A license for WEC 7 and 2013 is included in the price of Colibri iMX7 Solo 256MB and Colibri iMX7 Dual 512MB.
Notice: Colibri iMX7 Dual 1GB does not include a WEC license.
Get Started
FreeRTOS
FreeRTOS
FreeRTOS on Colibri iMX7 is supported directly by Toradex. FreeRTOS is ideal to run on the Cortex M4 core. The communication between Cortex M4 and Cortex A7 is achieved via Rpmsg.
For general information, check our FreeRTOS page.
Get Started
QNX
QNX
QNX on Colibri iMX7 is supported by our service partner Triadem.
Triadem will be soon offering a QNX demo image for Colbiri iMX7.
Get Started
CPU Details
CPU Name
CPU Type
CPU Clock
Floating Point Unit
NEON
L1 Instruction Cache
L1 Data Cache
L2 Cache
Memory
RAM
Flash
Connectivity
USB
Ethernet
Ethernet RMII
External Bus
I2C
SPI
UART
IrDA
PWM
GPIO
Analog Input
SDIO/SD/MMC
CAN
Multimedia
Individual Displays
Graphics Controller
RGB
Resistive Touch
Camera Parallel Interface
Analog Audio Line in
Analog Audio Mic in
Analog Audio Headphone out
Operating System
Windows Embedded Compact 2013
Embedded Linux
QNX
INTEGRITY RTOS
FreeRTOS
Preinstalled OS
Physical
Size
Temperature
Power Dissipation
Minimum Availability(1)
Pricing
Colibri iMX7 Dual 1GBColibri iMX7 Dual 512MBColibri iMX7 Solo 256MB
Buy Now Buy Now Buy Now
NXP®/Freescale i.MX 7DualNXP®/Freescale i.MX 7DualNXP®/Freescale i.MX 7Solo
ARM Cortex™-A7, Cortex™-M4ARM Cortex™-A7, Cortex™-M4ARM Cortex™-A7, Cortex™-M4
1.0 GHz (A7), 200 MHz (M4)1.0 GHz (A7), 200 MHz (M4)800 MHz (A7), 200 MHz (M4)
VFPv4VFPv4VFPv4
YesYesYes
32KB (A7), 16KB (M4)32KB (A7), 16KB (M4)32KB (A7), 16KB (M4)
32KB (A7), 16KByte (M4)32KB (A7), 16KByte (M4)32KB (A7), 16KByte (M4)
512KByte512KByte512KByte
1GB DDR3 (32bit)512MB DDR3 (32 Bit)256MB DDR3 (32 Bit)
4GB eMMC (8Bit)512MB NAND (8 Bit)512MB NAND (8 Bit)
1x Host (High Speed)
1x OTG (High Speed)
1x OTG (High Speed)
1x OTG (High Speed)
10/100 Mbit IEEE158810/100 Mbit IEEE158810/100 Mbit IEEE1588
1x1x
16 Bit Multiplexed16 Bit Multiplexed16 Bit Multiplexed
4x4x4x
4x4x4x
7x7x7x
1x1x1x
20x20x20x
Up to 125Up to 123Up to 123
4x (12 Bit)4x (12 Bit)4x (12 Bit)
2x 8 Bit2x 8 Bit2x 8 Bit
2x2x2x
1x1x1x
IntegratedIntegratedIntegrated
1920x1080x24bpp1920x1080x24bpp1920x1080x24bpp
4-wire4-wire4-wire
1x1x1x
1x (Stereo)1x (Stereo)1x (Stereo)
1x (Mono)1x (Mono)1x (Mono)
Contact ToradexSupportedSupported
SupportedSupportedSupported
Coming SoonComing SoonComing Soon
LinuxLinuxLinux
67.6 x 36.7 x 6.2 mm67.6 x 36.7 x 6.2 mm67.6 x 36.7 x 6.2 mm
-20° to +85° C-20° to +85° C-20° to +85° C
0.6 - ~1.1 W0.6 - ~1.1 W0.6 - ~0.9 W
202720272027
1-99 :USD 81.50
100-249 :USD 78.25
250-499 :USD 73.35
>=500 :USD 70.10
1-99 :USD 71.60
100-249 :USD 68.75
250-499 :USD 64.45
>=500 :RFQ
1-99 :USD 65.80
100-249 :USD 63.15
250-499 :USD 59.25
>=500 :USD 56.60
(1) Toradex guarantees minimum availability for products - not for a specific version of a product.
Notes: The SKU with 1GB RAM is an early product announcement. All provided information is preliminary and subject to change.
Please sign up to get notifications about the status and availability.
  ×Colibri Evaluation Board×Orchid Carrier Board×Iris Carrier Board×Viola Carrier Board×Aster Carrier Board
Colibri Evaluation BoardOrchid Carrier BoardIris Carrier BoardViola Carrier BoardAster Carrier Board
DatasheetDatasheetDatasheetDatasheetDatasheet
detail...detail...detail...detail...detail...
Connectivity
Supported ModulesEntire Colibri FamilyEntire Colibri FamilyEntire Colibri FamilyEntire Colibri FamilyEntire Colibri Family
Compact Flash Card Interface1x
USB4x Host (High Speed)
1x Device (High Speed)
1x OTG (High Speed)
2x Host (Full Speed)
1x Device (Full Speed)
1x OTG (High Speed)
2x Host (High Speed) /
1x Client (Shared)
2x (High Speed)
Ethernet10/100 Mbit10/100 Mbit10/100 Mbit10/100 Mbit10/100 Mbit
External BusUp to 32 Bit
I2Cup to 4x1x1x1x1x
SPIup to 4x2x1x1x1x
UART2x RS232
1x RS422/485
2x RS232 /
1x RS232
3x RS2323x2x TTL, 1x USB
IrDA1x1x
PWM4x4x4x4x4x
GPIOup to 158up to 20up to 26up to 35up to 39
Analog Input4x4x4x4x4x
SDIO/SD/MMC1x 4 Bit1x 4 Bit1x 4 Bit (microSD)1x 4 Bit (microSD)1x 4 Bit (Full Size)
CAN1x1x (Available with Colibri VFxx and iMX)1x (Available with Colibri VFxx and iMX)
Input / Output
Switches6x
LEDs4xup to 3x
Multimedia
LVDS1x Single Channel1x Single Channel
HDMI1x (Through DVI-I connector)1x (Through DVI-I connector)
VGA1x1x1x (Through DVI-I connector)1x (Shared with RGB)
RGB1x (18 Bit/24 Bit)1x (18 bit)
Capacitive TouchAdapter requiredAdapter required
Resistive Touch4/5-wire4-wire4/5-wire4-wire
Camera Parallel Interface1x— /
1x
Analog Audio Line in1x (Stereo)1x (Stereo) /
1x (Stereo)— /
1x (Stereo)
1x (Stereo)
Analog Audio Mic in1x (Mono)1x (Mono)1x (Mono)— /
1x (Mono)
1x (Mono)
Analog Audio Headphone out1x (Stereo)1x (Stereo)1x (Stereo)— /
1x (Stereo)
1x (Stereo)
Other
USB-to-RS232 Transceiver1x1x
RTC on Board1x1x1x1x (*Not Assembled) /
1x
Included AccessoryMating Power Plug (for X33)
24-way FFC 100mm (for X6)
Mating Power Plug (for X5)Mating Power Plug (for X17)
24-way FFC 35mm (for X4)
Altium CAE Data Freely AvailableYesYesYesYes
JTAGYesYes
Physical
Supply Voltage7-27V DC7-24V DC6-27V DC5V DC5V DC
On-Board Power Supplies5V 5A
3.3V 5A
5V 5A
3.3V 5A
5V 5A
3.3V 5A
5V (External)
3.3V 3A
3.3V 3A
Size200 x 200 mm160 x 100 mm100 x 72 mm74 x 74 mm100 x 80 mm
Temperature-30° to +85° C-10° to +70° C
-20° to +85° C
-40° to +85 °C /
-40° to +85° C
-25° to +85° C
8 Accessories
  • Proven reliability in many vibration and shock tests
  • Colibri carrier boards provide mounting holes (except for Viola)
  • Resolution: 800x480px
  • 18-bit RGB + TCON
  • 40 pin FFC cable to connect it with a Carrier Board
  • No special drivers required
  • Operating temperature: -20° to +70° C
  • 18-bit RGB + TCON
  • 40 pin and 10 pin FFC cable to connect it with a Carrier Board
  • Atmel touch driver
  • Operates in 2.4 GHz frequency bands with data rate up-to 150 Mbps, 802.11b/g/h-compatible
  • 1x1 MIMO technology improves eective throughput and range over existing 802.11 b/g products
  • Plug and Play (Linux, macOS X, Windows XP – 10, Windows 10 IoT Core and Windows Compact Embedded 6/7 compatible)
  • Uses Analog Devices, ADV7280 video decoder
  • Analogue Camera Input : 4 multiplexed video input channels, supporting NTSC / PAL / SECAM composite video signals
  • Cables: USB, Ethernet, RS232, Jumper Wires
  • Adapters: DVI to VGA, HDMI to DVI, USB to RS232, USB Micro-A to A (USB Micro-AB receptacle to Type A), RS232 Header to D-Sub, Iris Power-adapter
  • Compatible with: Apalis Evaluation Board, Ixora Carrier Board, Colibri Evaluation Board, Iris Carrier Board
  • 18-bit RGB to LVDS
  • 1mm pitch
  • Compatible with various Toradex carrier boards
  • 1.25mm pitch
4 Modules, 8 Carrier Boards, 8 Accessories
Sample Product
NXP®/Freescale i.MX 7Dual, ARM Cortex™-A7, Cortex™-M4, 1.0 GHz (A7), 200 MHz (M4), 1GB DDR3 (32bit), 4GB eMMC (8Bit), 10/100 Mbit IEEE1588 Ethernet, -20° to +85° C Temp. Range, Availability until 2027
Quantity
Unit Price
1-99100-249250-499500-999>1000
USD 81.50USD 78.25USD 73.35USD 70.10RFQ
low stock
Product Change Notification
NXP®/Freescale i.MX 7Dual, ARM Cortex™-A7, Cortex™-M4, 1.0 GHz (A7), 200 MHz (M4), 512MB DDR3 (32 Bit), 512MB NAND (8 Bit), 10/100 Mbit IEEE1588 Ethernet, -20° to +85° C Temp. Range, Availability until 2027
Quantity
Unit Price
USD 71.60USD 68.75USD 64.45USD 61.60RFQ
in stock
Sample Product
Quantity
Unit Price
USD 71.60USD 68.75USD 64.45RFQRFQ
low stock
Sample Product
NXP®/Freescale i.MX 7Solo, ARM Cortex™-A7, Cortex™-M4, 800 MHz (A7), 200 MHz (M4), 256MB DDR3 (32 Bit), 512MB NAND (8 Bit), 10/100 Mbit IEEE1588 Ethernet, -20° to +85° C Temp. Range, Availability until 2027
Quantity
Unit Price
USD 65.80USD 63.15USD 59.25USD 56.60RFQ
in stock
Evaluation Product
Connectivity: USB: 4x Host (High Speed)
1x OTG (High Speed), 10/100 Mbit Ethernet, up to 4x I2C, up to 4x SPI, 4x PWM, 4x ADC, 1x CAN, 6x Switches, 4x LEDs, up to 158 GPIOs
Physical: 7-27V DC Supply Voltage, 5V 5A
3.3V 5A On-Board Power Supplies, Size: 200 x 200 mm
Quantity
Unit Price
>1
USD 199.00
in stock
Volume Product
This product is only recommended for Colibri PXA modules
Connectivity: USB: 2x Host (Full Speed)
1x Device (Full Speed), 10/100 Mbit Ethernet, 1x I2C, 2x SPI, 4x PWM, 4x ADC, up to 20 GPIOs
Multimedia: Audio out: 1x (Stereo), Audio in: 1x (Stereo), 4-wire Resistive Touch
Physical: 7-24V DC Supply Voltage, 5V 5A
3.3V 5A On-Board Power Supplies, Size: 160 x 100 mm
Quantity
Unit Price
1-99
USD 99.00
in stock
Volume Product
Multimedia: Audio out: 1x (Stereo), 4-wire Resistive Touch
Quantity
Unit Price
1-99
USD 99.00
in stock
Volume Product
Small form-factor Pico-ITX Colibri ARM Computer Module family Carrier Board
Connectivity: USB: 1x Host (High Speed)
1x OTG (High Speed), 10/100 Mbit Ethernet, 1x I2C, 1x SPI, 4x PWM, 4x ADC, up to 26 GPIOs
Physical: 6-27V DC Supply Voltage, 5V 5A
3.3V 5A On-Board Power Supplies, Size: 100 x 72 mm
Quantity
Unit Price
USD 58.25USD 52.65USD 49.30USD 45.95RFQ
in stock
Connectivity: USB: 2x Host (High Speed), 10/100 Mbit Ethernet, 1x I2C, 1x SPI, 4x PWM, 4x ADC, 1x (Available with Colibri VFxx and iMX) CAN, up to 35 GPIOs
Physical: 5V DC Supply Voltage, 5V (External)
3.3V 3A On-Board Power Supplies, Size: 74 x 74 mm
Quantity
Unit Price
USD 23.55USD 22.40USD 21.30USD 20.20RFQ
in stock
Volume Product
Quantity
Unit Price
USD 23.55USD 22.40USD 21.30USD 20.20USD 19.05
in stock
Volume Product
1x Client (Shared), 10/100 Mbit Ethernet, 1x I2C, 1x SPI, 4x PWM, 4x ADC, 1x (Available with Colibri VFxx and iMX) CAN, up to 35 GPIOs
Quantity
Unit Price
USD 29.15USD 28.00USD 26.90USD 25.80RFQ
in stock
Volume Product
Small form-factor with header compatible with Arduino Uno and Raspberry Pi (RPi) maker boards
Connectivity: USB: 2x (High Speed)
1x Device (High Speed), 10/100 Mbit Ethernet, 1x I2C, 1x SPI, 4x PWM, 4x ADC, 1x (Available with Colibri VFxx and iMX) CAN, up to 3x LEDs, up to 39 GPIOs
Physical: 5V DC Supply Voltage, 3.3V 3A On-Board Power Supplies, Size: 100 x 80 mm
Quantity
Unit Price
USD 58.25USD 54.90USD 51.55USD 48.20RFQ
in stock
Volume Product
Fasteners for Colibri modules
Proven reliability in many vibration and shock tests, Colibri carrier boards provide mounting holes (except for Viola), 1 Fastener bag contains 100 Fasteners.
Quantity
Unit Price
USD 37.00USD 32.50USD 29.50USD 28.00RFQ
in stock
Sample Product
Resolution: 800x480px, 18-bit RGB + TCON, Touch: 4-Wire Resistive Touch, 40 pin FFC cable to connect it with a Carrier Board, No special drivers required, Operating temperature: -20° to +70° C, Range. Size: 164.9 (W) x 100.0 (H) x 13.0 (D) (max) mm.
Quantity
Unit Price
>1
USD 88.50
in stock
Sample Product
Capacitive Touch Displays it for Apalis & Colibri modules
Resolution: 800x480px, 18-bit RGB + TCON, 40 pin and 10 pin FFC cable to connect it with a Carrier Board, Atmel touch driver, Operating temperature: -20° to +70° C, Range. Size: 173.1 (W) x 112.5 (H) x 13.0 (D) (max) mm.
Quantity
Unit Price
>1
USD 99.70
in stock
LM816 USB WiFi | V1.0A
Sample Product
Operates in 2.4 GHz frequency bands with data rate up-to 150 Mbps, 802.11b/g/h-compatible, 1x1 MIMO technology improves eective throughput and range over existing 802.11 b/g products, Plug and Play (Linux, macOS X, Windows XP – 10, Windows 10 IoT Core and Windows Compact Embedded 6/7 compatible), BPSK, QPSK, 16 QAM, 64 QAM, DBPSK, DQPSK, and CCK modulation schemes, WEP, TKIP, and AES, WPA, WPA2 hardware encryption Schemes, Can be setup as a ad-hoc network via peer to peer communications.
Quantity
Unit Price
1-99100-249250-499>500
USD 19.05USD 14.06USD 12.35RFQ
in stock
Evaluation Product
Uses Analog Devices, ADV7280 video decoder, Analogue Camera Input : 4 multiplexed video input channels, supporting NTSC / PAL / SECAM composite video signals, Parallel data output format: 8-Bit Parallel ITU-R BT.656 with external HSync and VSync, No external power supply required, Compatible with Colibri Evaluation Board and Apalis Evaluation Board.
Quantity
Unit Price
USD 43.70USD 39.20USD 38.10USD 37.00RFQ
in stock
Evaluation Product
Cables: USB, Ethernet, RS232, Jumper Wires, Adapters: DVI to VGA, HDMI to DVI, USB to RS232, USB Micro-A to A (USB Micro-AB receptacle to Type A), RS232 Header to D-Sub, Iris Power-adapter, Power Adapter: 12VDC 30W with international plugs, Compatible with: Apalis Evaluation Board, Ixora Carrier Board, Colibri Evaluation Board, Iris Carrier Board.
Quantity
Unit Price
>1
USD 28.00
in stock
Evaluation Product
LVDS converters for Colibri modules
18-bit RGB to LVDS, 1mm pitch, Compatible with various Toradex carrier boards.
Quantity
Unit Price
USD 40.35USD 35.85USD 32.15USD 29.15RFQ
in stock
Evaluation Product
18-bit RGB to LVDS, 1.25mm pitch, Compatible with various Toradex carrier boards.
Quantity
Unit Price
in stock
