TI AM69 Computer on Module
Aquila AM69
  • Toradex's highest-performing SoM
  • Based on the TI AM69 processor with up to 8x ARM Cortex-A72 cores
  • State-of-the-art Deep Learning Accelerator with up to 32 TOPS
  • Ideal for robotics, AI, real-time control, and computer vision applications
  • Rugged board-to-board connector
  • LTS-supported Linux Software stack, including OTA, Remote Access, and Device Monitoring
Highlights
Higher Performance with 8x ARM Cortex-A72 Cores
Aquila AM69 is based on the high-performing TI AM69 SoC. It offers up to eight Cortex-A72 cores at 2.0 GHz for maximum performance and two Cortex-R5F microcontroller cores. That makes the Aquila AM69 a perfect fit for high-performance edge computing.
Built for AI and Computer Vision Applications
The Aquila AM69 is ideal for building cutting-edge AI and computer vision systems. Leverage Toradex tooling on the software side and high-performing NPU, ISP, and VPU units on the hardware side for use cases demanding the highest performance.
High-Performance Machine Learning
Aquila AM69's integrated neural network processing unit (NPU) achieves 32 TOPS for fast inference times, outperforming CPU- and GPU-based solutions in the same power range several times. Toradex provides integration with popular machine learning frameworks, such as TensorFlow.
Industrial Reliability
Aquila is engineered for industrial reliability and a long-lasting lifetime. That is reflected in its brand new, rugged board-to-board connector (approx. 400 pins), making Aquila AM69 the right choice for mission-critical applications.
Hard Real-Time Ready
With a heterogeneous multicore architecture, Aquila AM69 also offers two ARM Cortex-R5 for complex real-time and safety-critical applications with extremely low latency.
Cost-Optimized and Power-Efficient
The Aquila AM69 SoM offers superior performance than x86 devices, with lower power consumption. It is also better cost-optimized than other proprietary GPU-accelerated hardware solutions while showing equivalent performance.
Torizon for Remote Updates, Remote Access and Monitoring
Aquila AM69 is available with a tightly integrated, Torizon Cloud accelerating the development and facilitating the maintenance of your products. Some key features include highly secure and reliable remote updates, fleet monitoring, and remote access.
Toradex Aquila Family
The Aquila AM69 is part of the Aquila family and pin-to-pin-compatible with the other Aquila SoMs. Designed for industrial reliability and unparalleled performance, Aquila is the perfect fit for demanding applications working in harsh environments.
Ready to Power the Next-Generation of On-Device AI
Aquila AM69 is equipped with a 32 TOPS NPU to power state-of-the-art Artificial Intelligence and Machine Learning applications. Its high-speed camera interfaces also allow multiple 4K camera streams for computer vision applications, with dedicated Image and Video processing units.
Toradex offers support for industry-standard tools and frameworks in the areas of Machine Learning and Computer Vision.
32 TOPS NPU
Low Inference Latency
ISP and VPU
Fast Image and Video Processing
3x Quad-Lane MIPI CSI-2
Up To 12 Full HD Cameras Connected
State of the Art Tooling
Great Developer Experience
Torizon
Torizon makes modern, iterative product development easier by seamlessly integrating hardware, an OS, development tools, remote updates, and fleet monitoring. That makes it a scalable solution for devices requiring high reliability and security.
Torizon accelerates your Aquila AM69 project. The ready and maintained embedded Linux OS with simple tools allows you to focus on your application. Torizon is built with Continuous Delivery in mind, so you can ship early and update iteratively. Secure and Reliable Built-in Remote Updates, Device Monitoring, and Remote access reduces your risk. It lets you detect issues before they get serious, debug devices in the field, and take action. Torizon also makes it easy to comply with new regulations like the EU Cyber Resilience Act.
Get an Overview For Application Developer For Tech Leads
We wanted to focus our time and engineering resources on developing the application and solving related problems. And Torizon helped us to achieve this goal
Adrian Aschwanden,
Operating Systems
Aquila AM69 comes with a free maintained Embedded Linux Operating System. You can either take our Reference Images based on the Yocto Project, or you can use Torizon OS. Torizon OS is also built with the Yocto Project but it is a ready-to-use Embedded Linux distribution. It is configurable for your custom carrier board via the simple to use TorizonCore Builder Tool. This enables developers to concentrate solely on their applications, without having to worry about the underlying operating system and low-level device drivers.
Torizon Embedded Linux OS
Toradex develops and maintains a Yocto Project-compatible, production-quality Embedded Linux BSP in-house.
Features
FRONT
BACK
CPU Name TI AM 69
CPU Type Up to 8x Arm Cortex™-A72
Microcontroller 2x Arm Cortex™-R5F
CPU Clock 2.0 GHz (A72)
1.0 GHz (R5F)
RAM Up to 32GB LPDDR4 (128 Bit)
Flash Up to 128GB eMMC
This data is preliminary and is subject to change.
USB 3.2 1x DRD | 1x Host
Ethernet Gigabit with AVB (+2nd RGMII)
Wi-Fi 2.4/5/6 GHz Dual Band
2x2 Wi-Fi 6E (802.11ax)
Bluetooth Bluetooth 5.3
PCIe 2x (x2 Gen 3)
SerDes (SGMII) 4x
I2C 7x
SPI 2x
QSPI 1x
UART 4x
PWM 4x
Analog Input 8x
SDIO/SD/MMC 1x
CAN 4x
GPIO 16x
JTAG 1x
Neural Processing Unit (NPU) 32 TOPS
ISP 2x
Display Controller Triple
2D Acceleration Yes
3D Acceleration Yes
Video Decoder 2x
Video Encoder 2x
Display Serial Interface 2x Quad Lane MIPI DSI
Display Port 1x DP 1.4 or 1x eDP 1.4
Digital Audio 2x I2S
Camera Serial Interface 3x Quad Lane MIPI CSI-2 (12 Virtual Channels)
Size 85 x 60mm
Temperature -40° to +85° C
Power Dissipation Approx. 5W - 25W
Product Availability 2034+
Guide Me
Configure Aquila AM69
Let’s Go
Configure Your Own Aquila AM69
Aquila AM69
Guide Me
Accessories
  • 34 Pins 0.5mm FFC Ribbon Cable (250mm) to connect with a Carrier Board
  • Cable length: 100mm
  • Manufacturer: Unictron
  • Manufacturer: Chang Hong
  • Reference: DA-2458-02
Pigtail Antenna Cable MHF4 to RP-SMA 100mm and 200mm
  • Cable length: 200mm
  • Suitable for outdoor-usage (IP67)
CSI Camera Set 5MP Color AR0521
  • MIPI CSI-2 interface
  • onsemi AR0521 1/2.5" 5MP color image sensor with ISP
  • M12 lens mount (S-mount)
Videos
Toradex - Aquila Arm Family - A Sneak Peek
A compatibilidade de pinos dos SoMs da Toradex, juntamente com ferramentas como o Pinout Designer, facilita a escalabilidade e a flexibilidade do projeto para que possamos adicionar e implantar novos recursos rapidamente, minimizando as chances de redesenhar a arquitetura base.
Ed Bear,
Desenvolvedor de Software / Sistemas, Tarform
Roadmap
Min. Product Commitment
2034+
Hardware Roadmap
  • Q2'24
  • Q3'24
  • Q4'24
  • Q1'25
  • Q2'25
Aquila AM69 System on Module
  • In Development
  • Sample Production
  • Volume Production
Have a Question?
