Highlights
Toradex Easy Installer
Wi-Fi & Bluetooth
ARM CPU Cortex-A7
  • Optional dual-band 802.11ac Wi-Fi and Bluetooth 4.2
  • Powered by NXP® i.MX 6ULL application processor
  • Power-efficient and cost-optimized solution
  • Ideal for industrial IoT and embedded applications
  • Integrated security features
Powered by NXP i.MX 6ULL Processor
Colibri iMX6ULL is the first Toradex's Computer Module offering on-board Wi-Fi and Bluetooth. The Colibri iMX6ULL is a SODIMM-sized SoM based on NXP i.MX 6ULL application processor, featuring a power-efficient ARM® Cortex-A7 core.
Dual-band 802.11ac Wi-Fi and Bluetooth 4.2 connectivity
Colibri iMX6ULL offers a low-cost and power-efficient platform to build a wide range of IoT and embedded devices. The option of integrated, fully certified Wi-Fi and Bluetooth simplifies the carrier board design and extends the Toradex advantages to wireless solutions. This includes free technical support, a high-quality Linux BSP, product life-cycle management, a welcoming out-of-the-box experience and much more.
The Colibri iMX6ULL is a reliable platform with integrated security features which makes it ideal for connected industrial IoT applications. The module can be used for IoT gateways or edge devices running a full featured Linux. The SoM has a long-term availability until 2028 and it is available in -30° to +85°C industrial temperature range.
Colibri Family
The Colibri iMX6ULL module is a member of the extensive pin-compatible Colibri family. The Colibri form factor has proven itself in countless demanding applications since 2005. A large variety of Toradex and 3rd party carrier boards allow you to easily create customized single board computers. For fully customized carrier boards, Toradex provides extensive resources of reference projects, design guides and tools. Our proven partners provide cost effective customization services.
Off-the-shelf accessories and peripherals such as capacitive touch displays simplify product evaluation and rapid development.
Product Video
Latest information on the Colibri iMX6ULL
You can find the latest information about the Colibri iMX6ULL at the Toradex Developer Center.
This is a recently introduced product family based on the NXP i.MX 6ULL processor. Therefore the Colibri iMX6ULL SoMs, including the Wi-Fi / Bluetooth component, are suspect to change without any prior notice. Any feedback to the SoM regarding performance and product specification is highly welcome.
Toradex offers free support and maintenance for Embedded Linux on the NXP i.MX 6ULL processor based Colibri iMX6ULL SoM. This allows system designers to focus the application only, instead of focusing also on the OS and low-level device drivers. Other OS such as QNX will be supported by our partners.
Toradex Colibri iMX6ULL module comes with the pre-installed Toradex Easy Installer which offers an easy one-click installation of either Linux or Windows BSPs.
For general information about the advantages and features, check our Toradex Easy Installer page.
Get Started
Linux
Embedded Linux
Toradex carries out in-house development and maintenance of a Yocto project-compatible production-quality Embedded Linux BSP. Our extensive documentation and support makes sure your product reaches market in time. Full source code and Toradex developments are up-streamed into mainline. Colibri iMX6ULL comes pre-installed with Embedded Linux.
For general information about the advantages and features, check our Embedded Linux page.
Get Started
CPU Details
CPU Name
CPU Type
CPU Clock
Floating Point Unit
NEON
L1 Instruction Cache
L1 Data Cache
L2 Cache
Memory
RAM
Flash
Connectivity
USB
Ethernet
Ethernet RMII
Wi-Fi
Bluetooth
External Bus
I2C
SPI
UART
IrDA
PWM
GPIO
Analog Input
SDIO/SD/MMC
CAN
Multimedia
Display Controller
Graphics Controller
Digital Audio
RGB
Resistive Touch
Camera Parallel Interface
Operating System
Embedded Linux
Physical
Size
Temperature
Power Dissipation
Minimum Availability(1)
Pricing
Colibri iMX6ULL 512MB Wi-Fi / Bluetooth
Industrial Temperature (IT)
Colibri iMX6ULL 256MB
Buy Now Buy Now
NXP® i.MX 6ULLNXP® i.MX 6ULL
1x ARM Cortex™-A71x ARM Cortex™-A7
800 MHz528 MHz
VFPv3VFPv3
YesYes
32KB32KB
32KByte32KByte
128KByte128KByte
512MB DDR3L (16 Bit)256MB DDR3L (16 Bit)
512MB SLC NAND (8 Bit)128MB SLC NAND (8 Bit)
1x Host (High Speed)
1x OTG (High Speed)
1x OTG (High Speed)
10/100 Mbit IEEE158810/100 Mbit IEEE1588
1x1x
Dual-Band 802.11ac
4.2/BLE (Dual-Mode)
16bit
3x3x
2x3x
8x8x
1x1x
8x8x
Up to 88Up to 94
7x8x
1x2x
2x2x
SingleSingle
IntegratedIntegrated
3x stereo SAI3x stereo SAI
1366 x 768 x 18bpp1366 x 768 x 18bpp
4-wire4-wire
1x1x
SupportedSupported
67.6 x 36.7 x 6.2 mm67.6 x 36.7 x 6.2 mm
-30° to +85° C0° to 70 °C
TBDTBD
20282028
1-99 :$86.60
100-249 :$83.15
250-499 :$77.95
>=500 :$74.50
1-99 :$44.75
100-249 :$42.95
250-499 :$40.25
>=500 :$38.50
(1) Toradex guarantees minimum availability for products - not for a specific version of a product.
Note: The Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT is currently for development usage only! Please do make sure to not ship this module to any end customer. A certification roadmap will folow shortly.
  ×Colibri Evaluation Board×Iris Carrier Board×Viola Carrier Board×Aster Carrier Board
Colibri Evaluation BoardIris Carrier BoardViola Carrier BoardAster Carrier Board
DatasheetDatasheetDatasheetDatasheet
detail...detail...detail...detail...
Connectivity
Supported ModulesEntire Colibri FamilyEntire Colibri FamilyEntire Colibri FamilyEntire Colibri Family
USB4x Host (High Speed)
1x Device (High Speed)
1x OTG (High Speed)
1x OTG (High Speed)
2x Host (High Speed) /
1x Client (Shared)
2x (High Speed)
Ethernet10/100 Mbit10/100 Mbit10/100 Mbit10/100 Mbit
External BusUp to 32 Bit
I2Cup to 4x1x1x1x
SPIup to 4x1x1x1x
UART2x RS232
1x RS422/485
3x RS2323x2x TTL, 1x USB
IrDA1x
PWM4x4x4x4x
GPIOup to 158up to 26up to 35up to 39
Analog Input4x4x4x4x
SDIO/SD/MMC1x 4 Bit1x 4 Bit (microSD)1x 4 Bit (microSD)1x 4 Bit (Full Size)
CAN1x1x (Available with Colibri VFxx and iMX)1x (Available with Colibri VFxx and iMX)
Input / Output
Switches6x
LEDs4xup to 3x
Multimedia
LVDS1x Single Channel1x Single Channel
HDMI1x (Through DVI-I connector)1x (Through DVI-I connector)
VGA1x1x (Through DVI-I connector)1x (Shared with RGB)
RGB1x (18 Bit/24 Bit)1x (18 bit)
Capacitive TouchAdapter requiredAdapter required
Resistive Touch4/5-wire4/5-wire4-wire
Camera Parallel Interface1x— /
1x
Analog Audio Line in1x (Stereo)1x (Stereo)— /
1x (Stereo)
1x (Stereo)
Analog Audio Mic in1x (Mono)1x (Mono)— /
1x (Mono)
1x (Mono)
Analog Audio Headphone out1x (Stereo)1x (Stereo)— /
1x (Stereo)
1x (Stereo)
Other
USB-to-RS232 Transceiver1x1x
RTC on Board1x1x1x (*Not Assembled) /
1x
Included AccessoryMating Power Plug (for X33)
24-way FFC 100mm (for X6)
Mating Power Plug (for X17)
24-way FFC 35mm (for X4)
Altium CAE Data Freely AvailableYesYesYesYes
JTAGYesYes
Physical
Supply Voltage7-27V DC6-27V DC5V DC5V DC
On-Board Power Supplies5V 5A
3.3V 5A
5V 5A
3.3V 5A
5V (External)
3.3V 3A
3.3V 3A
Size200 x 200 mm100 x 72 mm74 x 74 mm100 x 80 mm
Temperature-10° to +70° C
-20° to +85° C
-40° to +85 °C /
-40° to +85° C
-25° to +85° C
7 Accessories
  • Proven reliability in many vibration and shock tests
  • Colibri carrier boards provide mounting holes (except for Viola)
  • Resolution: 800x480px
  • 18-bit RGB + TCON
  • 40 pin FFC cable to connect it with a Carrier Board
  • No special drivers required
  • Operating temperature: -20° to +70° C
  • 18-bit RGB + TCON
  • 40 pin and 10 pin FFC cable to connect it with a Carrier Board
  • Atmel touch driver
  • Operates in 2.4 GHz frequency bands with data rate up-to 150 Mbps, 802.11b/g/h-compatible
  • 1x1 MIMO technology improves eective throughput and range over existing 802.11 b/g products
  • Plug and Play (Linux, macOS X, Windows XP – 10, Windows 10 IoT Core and Windows Compact Embedded 6/7 compatible)
  • Cables: USB, Ethernet, RS232, Jumper Wires
  • Adapters: DVI to VGA, HDMI to DVI, USB to RS232, USB Micro-A to A (USB Micro-AB receptacle to Type A), RS232 Header to D-Sub, Iris Power-adapter
  • Compatible with: Apalis Evaluation Board, Ixora Carrier Board, Colibri Evaluation Board, Iris Carrier Board
  • 18-bit RGB to LVDS
  • 1mm pitch
  • Compatible with various Toradex carrier boards
  • 1.25mm pitch
2 Modules, 6 Carrier Boards, 6 Accessories
NXP® i.MX 6ULL, 1x ARM Cortex™-A7, 800 MHz, 512MB DDR3L (16 Bit), 512MB SLC NAND (8 Bit), 10/100 Mbit IEEE1588 Ethernet, -30° to +85° C Temp. Range, Availability until 2028
Quantity
Unit Price
1-99100-249250-499500-999>1000
$86.60$83.15$77.95$74.50RFQ
in stock
Sample Product
NXP® i.MX 6ULL, 1x ARM Cortex™-A7, 528 MHz, 256MB DDR3L (16 Bit), 128MB SLC NAND (8 Bit), 10/100 Mbit IEEE1588 Ethernet, 0° to 70 °C Temp. Range, Availability until 2028
Quantity
Unit Price
$44.75$42.95$40.25$38.50RFQ
in stock
Evaluation Product
Connectivity: USB: 4x Host (High Speed)
1x OTG (High Speed), 10/100 Mbit Ethernet, up to 4x I2C, up to 4x SPI, 4x PWM, 4x ADC, 1x CAN, 6x Switches, 4x LEDs, up to 158 GPIOs
Physical: 7-27V DC Supply Voltage, 5V 5A
3.3V 5A On-Board Power Supplies, Size: 200 x 200 mm
Quantity
Unit Price
>1
$199.00
in stock
Volume Product
Small form-factor Pico-ITX Colibri ARM Computer Module family Carrier Board
Connectivity: USB: 1x Host (High Speed)
1x OTG (High Speed), 10/100 Mbit Ethernet, 1x I2C, 1x SPI, 4x PWM, 4x ADC, up to 26 GPIOs
Physical: 6-27V DC Supply Voltage, 5V 5A
3.3V 5A On-Board Power Supplies, Size: 100 x 72 mm
Quantity
Unit Price
$58.25$52.65$49.30$45.95RFQ
in stock
Product Change Notification
Connectivity: USB: 2x Host (High Speed), 10/100 Mbit Ethernet, 1x I2C, 1x SPI, 4x PWM, 4x ADC, 1x (Available with Colibri VFxx and iMX) CAN, up to 35 GPIOs
Physical: 5V DC Supply Voltage, 5V (External)
3.3V 3A On-Board Power Supplies, Size: 74 x 74 mm
Quantity
Unit Price
$23.55$22.40$21.30$20.20RFQ
low stock
Volume Product
Quantity
Unit Price
$23.55$22.40$21.30$20.20$19.05
in stock
Volume Product
1x Client (Shared), 10/100 Mbit Ethernet, 1x I2C, 1x SPI, 4x PWM, 4x ADC, 1x (Available with Colibri VFxx and iMX) CAN, up to 35 GPIOs
Quantity
Unit Price
$29.15$28.00$26.90$25.80RFQ
in stock
Volume Product
Small form-factor with header compatible with Arduino Uno and Raspberry Pi (RPi) maker boards
Connectivity: USB: 2x (High Speed)
1x Device (High Speed), 10/100 Mbit Ethernet, 1x I2C, 1x SPI, 4x PWM, 4x ADC, 1x (Available with Colibri VFxx and iMX) CAN, up to 3x LEDs, up to 39 GPIOs
Physical: 5V DC Supply Voltage, 3.3V 3A On-Board Power Supplies, Size: 100 x 80 mm
Quantity
Unit Price
$58.25$54.90$51.55$48.20RFQ
in stock
Volume Product
Fasteners for Colibri modules
Proven reliability in many vibration and shock tests, Colibri carrier boards provide mounting holes (except for Viola), 1 Fastener bag contains 100 Fasteners.
Quantity
Unit Price
$37.00$32.50$29.50$28.00RFQ
in stock
Sample Product
Resolution: 800x480px, 18-bit RGB + TCON, Touch: 4-Wire Resistive Touch, 40 pin FFC cable to connect it with a Carrier Board, No special drivers required, Operating temperature: -20° to +70° C, Range. Size: 164.9 (W) x 100.0 (H) x 13.0 (D) (max) mm.
Quantity
Unit Price
>1
$88.50
in stock
LM816 USB WiFi | V1.0A
Sample Product
Operates in 2.4 GHz frequency bands with data rate up-to 150 Mbps, 802.11b/g/h-compatible, 1x1 MIMO technology improves eective throughput and range over existing 802.11 b/g products, Plug and Play (Linux, macOS X, Windows XP – 10, Windows 10 IoT Core and Windows Compact Embedded 6/7 compatible), BPSK, QPSK, 16 QAM, 64 QAM, DBPSK, DQPSK, and CCK modulation schemes, WEP, TKIP, and AES, WPA, WPA2 hardware encryption Schemes, Can be setup as a ad-hoc network via peer to peer communications.
Quantity
Unit Price
1-99100-249250-499>500
$19.05$14.06$12.35RFQ
in stock
Evaluation Product
Cables: USB, Ethernet, RS232, Jumper Wires, Adapters: DVI to VGA, HDMI to DVI, USB to RS232, USB Micro-A to A (USB Micro-AB receptacle to Type A), RS232 Header to D-Sub, Iris Power-adapter, Power Adapter: 12VDC 30W with international plugs, Compatible with: Apalis Evaluation Board, Ixora Carrier Board, Colibri Evaluation Board, Iris Carrier Board.
Quantity
Unit Price
>1
$28.00
in stock
Evaluation Product
LVDS converters for Colibri modules
18-bit RGB to LVDS, 1mm pitch, Compatible with various Toradex carrier boards.
Quantity
Unit Price
$40.35$35.85$32.15$29.15RFQ
in stock
Evaluation Product
18-bit RGB to LVDS, 1.25mm pitch, Compatible with various Toradex carrier boards.
Quantity
Unit Price
in stock
