TI Sitara AM62 Computer on Module
Verdin AM62
  • An attractive entry point to the Verdin ecosystem with the lowest total cost of ownership
  • TI AM62x Sitara™ processors with up to 4x Cortex-A53 cores
  • Scalability via pin-compatibility with the Verdin iMX8M Mini and Plus SoMs
  • Integrated OTA remote updates, device monitoring, and remote access with Torizon
  • Dual-Band 2.4/5 GHz 1x1 Wi-Fi 4 (802.11n) + Bluetooth 5.2
  • (optional) Dual-band 2.4/5 GHz 1x1 Wi-Fi 6 (802.11ax) + Bluetooth 5.3 (available for Custom Configuration)
  • Advanced power management and low-power modes for power-constrained applications
  • Hardware-based security for secure boot and cryptographic acceleration
Highlights
Cost Effective 64-bit performance
The Texas Instruments (TI) AM62x SoC comes with up to four powerful 64-bit Armv8 Cortex-A53 cores, making it a cost effective choice for running Linux with a modern graphical user interface. The Verdin AM62 targets a wide range of applications, including Industrial Automation, Medical, Transportation, Smart Cities, Test and Measurement, and many more.
Verdin Product Family
Hard real-time-ready
The heterogeneous multicore architecture allows the offloading of critical hard real-time tasks to the Cortex-M4 processor for extremely low latency. Toradex provides tooling and FreeRTOS to simplify development. You can also use the asymmetric multicore architecture for a connected low power mode or to increase security.
Power-optimized
The Verdin AM62 SoM powered by the TI Sitara AM623 SoC features a wide input voltage range that allows it to be powered from a broad range of power sources. Driven by the need for more power-efficient devices, and supported by the decreasing process sizes, the I/O voltage levels of the SoC pins are trending to decrease too. Both the wide input voltage range and the 1.8V I/O voltage make the power supply designs for a Verdin carrier board simple, easy, and cost-efficient. These features altogether make the Verdin family of SoMs perfectly suited for battery-powered applications as well.
Modern, future-proof interfaces
The AM62 System on Module offers a wide range of interfaces ranging from simple GPIOs, industry-standard I2C, SPI, USB, CAN FD, and UART buses to MIPI CSI camera interfaces. An optional MIPI DSI display interface is available on some SoM configurations. The Verdin AM62 System on Module features a Gigabit Ethernet PHY with IEEE1588 support on the module. The SoC features a second Ethernet MAC with an RGMII interface for adding a Gigabit Ethernet PHY on the carrier board for dual Ethernet applications.
Wireless Connectivity
The Sitara AM62 SoM is available with an optional Wi-Fi and Bluetooth interface. The wireless interfaces provided offer state-of-the-art integration for wireless devices and infrastructure and contribute to a great out-of-the-box end-user experience.
Torizon for Updates, Remote Access and Monitoring
The AM62 SoM is available with a tightly integrated Torizon Cloud (formerly Torizon Platform) accelerating the development and maintaining your products. Some key features include highly secure and reliable, remote and offline updates, fleet monitoring and remote access.
Torizon
Torizon
Torizon makes modern, iterative product development easier by seamlessly integrating hardware, an OS, development tools, remote updates and fleet monitoring. This makes it a scalable solution for devices requiring high reliability and security.
Torizon accelerates your Verdin AM62 project. The ready and maintained embedded Linux OS with simple tools allow you to focus on your application. Torizon is built with Continuous Delivery in mind, so you can ship early and update iterative. Secure and Reliable Built-in Remote Updates, Device Monitoring, and Remote access reduces your risk. It lets you detect issues before they get serious, debug devices in the field, and take action. Torizon also makes it easy to comply with new regulations like the EU Cyber Resilience Act.
Get an overview For Application Developer For Tech Leads
We wanted to focus our time and engineering resources on developing the application and solving related problems. And Torizon helped us to achieve this goal
Adrian Aschwanden,
Operating Systems
Verdin AM62 comes with a free maintained Embedded Linux Operating System. You can either take our Reference Images based on the Yocto Project, or you can use Torizon OS. Torizon OS is also built with the Yocto Project but it is a ready-to-use Embedded Linux distribution. It is configurable for your custom carrier board via the simple to use TorizonCore Builder Tool. This enables developers to concentrate solely on their applications, without having to worry about the underlying operating system and low-level device drivers.
Torizon Embedded Linux OS
Features
Up to 2GB LPDDR4 (16 bit)
Gigabit Ethernet Transceiver
Power Management IC (PMIC)
FRONT
BACK
CPU Name TI AM 625/623
CPU Type 4x Arm Cortex™-A53
Microcontroller 1x Arm Cortex™-M4F
CPU Clock 1.4 GHz (A53)
400 MHz (M4F)
NEON Yes
L1 Instruction Cache 32KB (A53)
L1 Data Cache 32KB (A53)
L2 Cache 512KB
RAM Up to 2GB LPDDR4 (16 Bit)
Flash Up to 16GB eMMC
*Dual-band 2.4/5 GHz 1x1 Wi-Fi 6 (802.11ax) + Bluetooth 5.3 (available for Custom Configuration)
USB 2.0 1x Host / 1x OTG
Ethernet Gigabit with TSN (+2nd RGMII)
Wi-Fi Dual-Band 2.4/5 GHz 1x1 Wi-Fi 4 (802.11n)*
Bluetooth Bluetooth 5.2*
I2C 4x
SPI 5x
QSPI/OSPI 1x
UART 9x
PWM 6x
GPIO 104x
Analog Input 4x
SDIO/SD/MMC 2x
CAN 3x (CAN FD)
JTAG 1x
PRUSS Yes
Display Controller Dual
Graphics Controller 3D: Yes
2D: Yes
Display Serial Interface 1x Quad Lane MIPI DSI
LVDS 1x (up to 1920x1080)
HDMI Via External Conversion From MIPI DSI
Digital Audio 2x McASP: I2S or TDM
2D Acceleration Yes
3D Acceleration Yes
Camera Serial Interface 1x Quad Lane MIPI CSI-2
Size 69.6 x 35.00 x 6.2 mm
Temperature -40° to +85° C
Power Dissipation Approx. 1.1W - 3.1W
Product Availability 2033+
Guide Me
Volume price starting from $31.90
Get Volume Quote
Configure Verdin AM62
Let’s Go
In Volume starting
from $31.90
Verdin AM62 Quad
2GB Wi-Fi / Bluetooth IT
PN: 0076
Verdin AM62 Quad 2GB Wi-Fi / Bluetooth IT
  • A53
  • A53
  • A53
  • A53
  • M4F
  • 3D GPU
  • 2GB RAM
  • 16GB FLASH
  • -40° to +85° C
Verdin AM62 Dual
1GB Wi-Fi / Bluetooth IT
PN: 0075
Verdin AM62 Dual 1GB Wi-Fi / Bluetooth IT
  • A53
  • A53
  • M4F
  • 3D GPU
  • 1GB RAM
  • 8GB FLASH
  • -40° to +85° C
Verdin AM62 Dual
1GB IT
PN: 0074
Verdin AM62 Dual 1GB IT
  • A53
  • A53
  • M4F
  • 3D GPU
  • 1GB RAM
  • 8GB FLASH
  • -40° to +85° C
Verdin AM62 Dual
1GB ET
PN: 0073
Verdin AM62 Dual 1GB ET
  • A53
  • A53
  • M4F
  • 1GB RAM
  • 4GB FLASH
  • -25° to +85° C
Verdin AM62 Solo
512MB Wi-Fi / Bluetooth IT
PN: 0072
Verdin AM62 Solo 512MB Wi-Fi / Bluetooth IT
  • A53
  • M4F
  • 512MB RAM
  • 4GB FLASH
  • -40° to +85° C
Verdin AM62 Solo
512MB
PN: 0071
  • A53
  • M4F
  • 512MB RAM
  • 4GB FLASH
  • -0° to +70° C
Configure Your Own Verdin AM62
Verdin AM62
1x Arm Cortex™-M4F
Guide Me
Get Started
Verdin AM62 Evaluation Kit
$601.00
  • Up to four Cortex-A53 1.4 GHz processors
  • Cortex-M4F processor with speeds up to 400 MHz
  • TI AM62X applications processor
  • Linux Support included
Buy Now
Verdin AM62 Evaluation Kit 2
$306.00
Buy Now
Carrier Boards
Learn more about SBCs and Carrier Boards
Verdin Development Board with HDMI Adapter
Datasheet
Dahlia Carrier Board with HDMI Adapter
Datasheet
Mallow Carrier Board
Datasheet
Ivy Carrier Board
Datasheet - Contact Us
Verdin Partner Carrier Boards
Supported Modules
USB 3.0
USB 2.0
USB 2.0 Debug
Ethernet
PCIe
I2C
SPI
QSPI
UART
PWM
GPIO
Analog Input
RS232
RS485
SDIO/SD/MMC
CAN
Type-specific Extension Connector
JTAG
Low-speed Extension Connector
2x USB-A (Host)
1x USB-C (DualRole)
1x USB-C
2x Gigabit
1x (Mini PCIe)
4x
1x
1x
4x
3x
Up to 98x
4x
1x
1x
1x 4 Bit (Full Size)
2x
Yes
Yes
2x USB-A (Host)
1x USB-C (DualRole)
1x USB-C
1x Gigabit
1x (Mini PCIe)
3x
1x
1x
4x
3x
Up to 47x
4x
1x 4 Bit (microSD)
1x
Yes
1x USB-A (Host)
1x USB-A (Host), 1x USB-C (DualRole)
1x USB-C
1x Gigabit
1x (Mini PCIe)
2x
1x
4x
2x
31x
4x
1x 4 Bit (microSD)
1x Via transceiver / 1x On extension connector
Yes
2x
Entire Verdin Family
2x Host
1x USB-C (DualRole)
Gigabit
1x M.2 (Key B)
4x
1x
4x (1.8V levels)
2x
Up to 40x
4x
1x 4 Bit (microSD)
2x (without transceivers)
2x
2x Host
1x OTG
2x Gigabit
1x (Mini PCIe)
1x (extension connector)
1x RS232
1x RS485
2x isolated digital inputs
4x isolated digital outputs (photo relays)
2x Analog Input
0-25mA
1x 4 Bit (microSD)
2x (with transceivers)
up to 4x Host
up to 2x 10/100 MBit
1x
1x
1x RS-422, 1x RS-485
up to 4x
up to 24x
up to 4x
1x
Up to 2x
LEDs
4x
1x RGB: power on and status
2x RGB: user configurable
LVDS
HDMI
Digital Audio
VGA
RGB
Capacitive Touch Interface
Resistive Touch
Analog Audio Line in
Analog Audio Mic in
Analog Audio Headphone out
1x (via optional Verdin DSI to LVDS Adapter)
1x Native / 1x Via included Verdin DSI to HDMI Adapter
1x I2S
1x (Stereo)
1x (Stereo)
1x (Stereo)
1x (Stereo)
1x (Mono)
1x (Stereo)
1x Native / 1x Converted from the Verdin MIPI DSI interface
1x I2S
1x Dual Channel
1x
1x I2S
Yes
Yes
1x
1x
1x
1x
up to 4/5-wire
1x (Stereo)
1x (Mono)
1x (Stereo)
RTC on Board
TPM
1x (CR1025)
1x TPM2.0
Yes
1x (CR1025)
1x TPM2.0
Yes
1x
Supply Voltage
On-Board Power Supplies
Size
Temperature
7-24V DC ±10%
250mm x 200mm
0° to 70° C
5-24V DC ±10% or USB-C (PD and BC)
120mm x 120mm
0° to 70° C
8-25V DC ±10%
120mm x 120mm
0° to 60° C
7-24V DC ±10%
5V 6A
3.3V 7A
1.8V 2A
100 x 72 mm (Pico-ITX)
-25° to 85° C
8-72V
125 x 90 mm
-40°C to 85° C
5-36V DC
-40° to 85° C
Intended Use
Pricing
For Evaluation/Development
1 : $322.40
1 : $182.80
1 : $198.90
For End Products
1-99 : $107.50
>99 : RFQ
For End Products
Accessories
Verdin Industrial Heatsink Type 1
  • Compatible with Verdin iMX8M Mini, iMX8M Plus and AM62
  • 4 screws (M2x10mm) included with each heatsink for easy mounting to Verdin Carrier Boards
  • Manufacturer: Chang Hong
  • Reference: DA-2458-02
Videos
Verdin AM62 System on Module powered by TI Sitara AM62x processor | Overview
Verdin AM62 at Embedded World
Webinar: Develop Modern and Competitive Products with the Verdin AM62
The pin-compatibility of Toradex’s SOMs, along with tools such as the Pinout Designer, facilitate scalability and flexibility of design so that we can rapidly add and deploy new features while minimizing redesign of the fundamental architecture.
Ed Bear,
Software / Systems Developer, Tarform
Ecosystem
To get your products to market fast, with low risk and low engineering costs, you need more than just a System on Module with a stable operating system or BSP. We understand this, which is why we at Toradex are collaborating with a wide range of partners to make your life easier. Here are a few highlights. To find more, browse our Developer Page and take a look at our Partner Network.
Toradex Easy Installer
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your Verdin iMX8M Plus and choose an OS!
Learn More
Displays
The Verdin AM62 provides HW-accelerated graphics and multiple display interfaces, making it ideal for Graphical Human Machine Interfaces (HMI). Toradex is partnering closely with display manufacturers providing high-quality displays with guaranteed longevity suitable for industrial and medical applications. Toradex tools make it easy to integrate the display of your choice.
Riverdi Displays
With Riverdi displays we work on offering a broad range of high-resolution, high-brightness embedded LCD displays. The MIPI DSI display interface allows you to showcase color-rich interfaces with smooth animations.
Get in touch with us
Roadmap
Min. Product Commitment
As per TI Roadmap
2033
Hardware Roadmap
For more details about PID8 level changes and historical releases please refer to the developer page.
  • Q4'23
  • Q1'24
  • Q2'24
  • Q3'24
  • Q4'24
0076 Verdin AM62 Quad 2GB Wi-Fi / Bluetooth IT
0075 Verdin AM62 Dual 1GB Wi-Fi / Bluetooth IT
0074 Verdin AM62 Dual 1GB IT
0073 Verdin AM62 Dual 1GB ET
0072 Verdin AM62 Solo 512MB Wi-Fi / Bluetooth IT
0071 Verdin AM62 Solo 512MB
  • In Development
  • Sample Production
  • Volume Production
Software Support Status
For latest news release refer
Linux BSP | Torizon OS BSP
Have a Question?
