Colibri VF61
The Colibri VF61 is a SODIMM sized computer module based on the NXP®/Freescale Vybrid embedded system-on-a-chip. The Cortex A5 CPU core peaks at 500 MHz and an additional M4 core runs at 167Mhz. The module delivers cost effective CPU and graphic performance with minimum power consumption.
Highlights
Powered by NXP®/Freescale Vybrid Processor: VF6xx Heterogeneous Multi-core
The Colibri VF61 is a SODIMM-sized computer module based on the NXP/Freescale Vybrid embedded System-on-Chip (SoC). The Arm Cortex-A5 CPU core peaks at 500 MHz and an additional M4 core runs at 167 MHz. The module delivers cost effective processing and graphics performance with minimal power consumption.
The NXP/Freescale VF6xx SoC possesses a heterogeneous/asymmetrical multi-core architecture. The two cores – Arm Cortex-A5 and Arm Cortex-M4 – can concurrently run different operating systems. This SoC architecture is ideal for applications with diverse real-time & mixed-criticality requirements in which the Arm Cortex-A5 runs a conventional OS such as Linux supporting UI and high throughput requirements while the Arm Cortex-M4 runs a RTOS for real-time tasks.
Traditionally, real-time and non-real-time requirements are often handled by separate processors on separate chips. Microcontrollers are often used for real-time tasks while microprocessors perform less time critical high-level tasks. Such an architecture has significant inter-chip communication over-head and suffers from duplicate resources & interfaces. In heterogeneous multi-core architectures, different processing cores are placed on a single silicon die. This allows the Colibri VF61 to provide a fast multi-core communication channel, inter-processor interrupts and shared resources and devices.
Check out the video on asymmetrical multicore processing for reliable, complex embedded systems, here
Heterogeneous Multi-core: Ideal for real-time Applications
The Colibri VF61 is ideal for simple Human Machine Interfaces (HMI) in appliances and industrial machines, secure control of infrastructure and manufacturing equipment, energy conversion applications (such as motor drives and power inverters), ruggedized wired and wireless connectivity, and control of mobile battery-operated systems such as robots and industrial vehicles. Due to the asymmetrical multi-core support, Colibri VF61 can be used in a variety of real-time applications.
Colibri VF61 is a reference platform for Qt for Device Creation. For more details, check here
Easy Performance Upgrade
Existing customers will benefit from an extremely easy migration path between the current Colibri iMX6, Colibri PXAxxx or Colibri Txx module range to the Colibri VF61 – all Colibri modules are electrically pin compatible. New customers will also appreciate the ability to select the Colibri module most suitable for their application to achieve the optimum price/performance balance without the need to support different carrier board designs.
Latest Information on Colibri VF61
You can find the latest information on Colibri VF61 at the Toradex Developer Center
Toradex Developer CenterOperating Systems
Toradex offers free support and maintenance for Windows Embedded Compact and Embedded Linux on the NXP®/Freescale Vybrid VF6xx Computer on Module - Colibri VF61. This allows system designers to focus the application only, instead of focusing also on the OS and low-level device drivers.
Windows Embedded CE 6.0, Windows Embedded Compact 7 and 2013 are supported on Colibri VF61. The development and maintenance is carried out in-house by Toradex. WEC allows you to use Microsoft .Net Compact Framework and Visual Studio.
Carrier Boards
- No special drivers required
- Atmel touch driver
Buy Now
NXP® Vybrid™ VF6XX, 1x Arm Cortex™-A5, 500 MHz (A5), 167 MHz (M4), 256MB DDR3 (16 Bit) (or 128MB with ECC), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2028
Quantity1-99>99
Unit Price$81.85
Quantity>0
Unit Price$229.00
Quantity1-99>99
Unit Price$79.95
Quantity1-99>99
Unit Price$33.60
Quantity1-99>99
Unit Price$40.30
Quantity>0
Unit Price$69.90
Fasteners for Colibri modules
Quantity>0
Unit Price$19.90
Touch: 4-Wire Resistive Touch. 40 pin FFC cable (250mm) to connect it with a Carrier Board. No special drivers required. -20° to 70° C Temp, Range. Size: 164.9 x 100.0 x 13.0 mm.
Quantity>0
Unit Price$100.00
40 pin and 10 pin FFC cable (250mm) to connect it with a Carrier Board. Atmel touch driver. -20° to 70° C Temp, Range. Size: 173 x 112 x 13 mm.
Quantity>0
Unit Price$119.90
Plug and Play (Windows Compact Embedded 6/7 compatible). BPSK, QPSK, 16 QAM, 64 QAM, DBPSK, DQPSK, and CCK modulation schemes. WEP, TKIP, and AES, WPA, WPA2 hardware encryption Schemes. Can be setup as a ad-hoc network via peer to peer communications. -10° to 60° C Temp, Range. Size: 17 x 15 x 8 mm.
Quantity1-99>99
Unit Price$28.05
