TI Sitara AM62 Computer on Module
Verdin AM62
- An attractive entry point to the Verdin ecosystem with the lowest total cost of ownership
- TI AM62x Sitara™ processors with up to 4x Cortex-A53 cores
- Scalability via pin-compatibility with the Verdin iMX8M Mini and Plus SoMs
- Integrated OTA remote updates, device monitoring, and remote access with Torizon
- Dual-Band 2.4/5 GHz 1x1 Wi-Fi 4 (802.11n) + Bluetooth 5.2
- (optional) Dual-band 2.4/5 GHz 1x1 Wi-Fi 6 (802.11ax) + Bluetooth 5.3 (available for Custom Configuration)
- Advanced power management and low-power modes for power-constrained applications
- Hardware-based security for secure boot and cryptographic acceleration
하이라이트
The Texas Instruments (TI) AM62x SoC comes with up to four powerful 64-bit Armv8 Cortex-A53 cores, making it a cost effective choice for running Linux with a modern graphical user interface. The Verdin AM62 targets a wide range of applications, including Industrial Automation, Medical, Transportation, Smart Cities, Test and Measurement, and many more.
Verdin Product Family
The heterogeneous multicore architecture allows the offloading of critical hard real-time tasks to the Cortex-M4 processor for extremely low latency. Toradex provides tooling and FreeRTOS to simplify development. You can also use the asymmetric multicore architecture for a connected low power mode or to increase security.
The Verdin AM62 SoM powered by the TI Sitara AM623 SoC features a wide input voltage range that allows it to be powered from a broad range of power sources. Driven by the need for more power-efficient devices, and supported by the decreasing process sizes, the I/O voltage levels of the SoC pins are trending to decrease too. Both the wide input voltage range and the 1.8V I/O voltage make the power supply designs for a Verdin carrier board simple, easy, and cost-efficient. These features altogether make the Verdin family of SoMs perfectly suited for battery-powered applications as well.
The AM62 System on Module offers a wide range of interfaces ranging from simple GPIOs, industry-standard I2C, SPI, USB, CAN FD, and UART buses to MIPI CSI camera interfaces. An optional MIPI DSI display interface is available on some SoM configurations. The Verdin AM62 System on Module features a Gigabit Ethernet PHY with IEEE1588 support on the module. The SoC features a second Ethernet MAC with an RGMII interface for adding a Gigabit Ethernet PHY on the carrier board for dual Ethernet applications.
The Sitara AM62 SoM is available with an optional Wi-Fi and Bluetooth interface. The wireless interfaces provided offer state-of-the-art integration for wireless devices and infrastructure and contribute to a great out-of-the-box end-user experience.
The AM62 SoM is available with a tightly integrated Torizon Cloud (formerly Torizon Platform) accelerating the development and maintaining your products. Some key features include highly secure and reliable, remote and offline updates, fleet monitoring and remote access.
Torizon
Torizon
Torizon makes modern, iterative product development easier by seamlessly integrating hardware, an OS, development tools, remote updates and fleet monitoring. This makes it a scalable solution for devices requiring high reliability and security.
Torizon accelerates your Verdin AM62 project. The ready and maintained embedded Linux OS with simple tools allow you to focus on your application. Torizon is built with Continuous Delivery in mind, so you can ship early and update iterative. Secure and Reliable Built-in Remote Updates, Device Monitoring, and Remote access reduces your risk. It lets you detect issues before they get serious, debug devices in the field, and take action. Torizon also makes it easy to comply with new regulations like the EU Cyber Resilience Act.
Get an overview For Application Developer For Tech LeadsWe wanted to focus our time and engineering resources on developing the application and solving related problems. And Torizon helped us to achieve this goal
Adrian Aschwanden,
운영 체제
Verdin AM62 comes with a free maintained Embedded Linux Operating System. You can either take our Reference Images based on the Yocto Project, or you can use Torizon OS. Torizon OS is also built with the Yocto Project but it is a ready-to-use Embedded Linux distribution. It is configurable for your custom carrier board via the simple to use TorizonCore Builder Tool. This enables developers to concentrate solely on their applications, without having to worry about the underlying operating system and low-level device drivers.
특징
Up to 2GB LPDDR4 (16 bit)
Gigabit Ethernet Transceiver
Power Management IC (PMIC)
CPU Name | TI AM 625/623 |
Microcontroller | 1x Arm Cortex™-M4F |
CPU Clock | 1.4 GHz (A53) 400 MHz (M4F) |
NEON | Yes |
L1 Instruction Cache | 32KB (A53) |
L1 Data Cache | 32KB (A53) |
L2 Cache | 512KB |
RAM | Up to 2GB LPDDR4 (16 Bit) |
Flash | Up to 16GB eMMC |
Display Controller | Dual |
Graphics Controller | 3D: Yes 2D: Yes |
Display Serial Interface | 1x Quad Lane MIPI DSI |
LVDS | 1x (up to 1920x1080) |
Digital Audio | 2x McASP: I2S or TDM |
2D Acceleration | Yes |
3D Acceleration | Yes |
Details | |
Details | |
Details | |
Coming Soon | |
Contact Us | |
Contact Us |
Size | 69.6 x 35.00 x 6.2 mm |
Power Dissipation | Approx. 1.1W - 3.1W |
최소한 다량 구매
from US$31.90
Verdin AM62 Quad
2GB Wi-Fi / Bluetooth ITPN: 0076
A53
A53
A53
A53
M4F
3D GPU
2GB RAM
16GB FLASH
-40° to +85° C
Verdin AM62 Dual
1GB Wi-Fi / Bluetooth ITPN: 0075
A53
A53
M4F
3D GPU
1GB RAM
8GB FLASH
-40° to +85° C
Verdin AM62 Dual
1GB ITPN: 0074
A53
A53
M4F
3D GPU
1GB RAM
8GB FLASH
-40° to +85° C
Verdin AM62 Dual
1GB ETPN: 0073
A53
A53
M4F
1GB RAM
4GB FLASH
-25° to +85° C
Verdin AM62 Solo
512MB Wi-Fi / Bluetooth ITPN: 0072
A53
M4F
512MB RAM
4GB FLASH
-40° to +85° C
최적의 SoM을 선택하는 데 도와주세요
안내해주세요Get Started
Verdin AM62 Evaluation Kit
US$601.00
- Up to four Cortex-A53 1.4 GHz processors
- Cortex-M4F processor with speeds up to 400 MHz
- TI AM62X applications processor
- Linux Support included
Verdin AM62 Evaluation Kit 2
US$306.00
캐리어 보드
SBC와 캐리어 보드에 대해 자세히 알아보기액세서리
- Manufacturer: Chang Hong
- Reference: DA-2458-02
- Cable length: 100mm
Videos
Verdin AM62 System on Module powered by TI Sitara AM62x processor | Overview
Verdin AM62 at Embedded World
Webinar: Develop Modern and Competitive Products with the Verdin AM62
생태계
To get your products to market fast, with low risk and low engineering costs, you need more than just a System on Module with a stable operating system or BSP. We understand this, which is why we at Toradex are collaborating with a wide range of partners to make your life easier. Here are a few highlights. To find more, browse our Developer Page and take a look at our Partner Network.
Toradex Easy Installer
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your Verdin iMX8M Plus and choose an OS!
Learn MoreDisplays
The Verdin AM62 provides HW-accelerated graphics and multiple display interfaces, making it ideal for Graphical Human Machine Interfaces (HMI). Toradex is partnering closely with display manufacturers providing high-quality displays with guaranteed longevity suitable for industrial and medical applications. Toradex tools make it easy to integrate the display of your choice.
Riverdi Displays
With Riverdi displays we work on offering a broad range of high-resolution, high-brightness embedded LCD displays. The MIPI DSI display interface allows you to showcase color-rich interfaces with smooth animations.
Get in touch with us로드맵
Hardware Roadmap
- Q2'24
- Q3'24
- Q4'24
- Q1'25
- Q2'25
- In Development
- Sample Production
- Volume Production
Software Support Status
