NXP® i.MX 8M Plus
Computer on Module
Verdin iMX8M Plus
하이라이트
High-Performance Machine Learning
The integrated neural network processing unit (NPU) was designed from the ground up to execute deep learning inference, and to outperform CPU- and GPU-based solutions in the same power range by several times. Toradex provides integration with popular machine learning frameworks, such as TensorFlow.
Seamless Camera Integration
Toradex closely partners with leading providers of embedded camera modules to offer you a selection of easy-to-integrate camera solutions, reducing time-to-market and risk.
Torizon for Remote Updates and Fleet Monitoring
Ready for Hard-Real-Time
The heterogeneous multicore architecture allows the offloading of critical hard real-time tasks to the Cortex-M7 processors for extremely low latency. Toradex provides tooling and FreeRTOS to simplify development. You can also use the asymmetric multicore architecture for a connected low-power mode or to increase security. The Cortex-M7, with a clock speed of 800 MHz, is a fast and capable microcontroller.
High-Performance, Pre-certified Wi-Fi and Bluetooth
Simplify your design with pre-certified wireless options — from the module to the antennas — to make end-device certification processes more predictable while cutting costs. The latest 802.11ac standard and support for multiantenna setups contribute to a great end-user experience out-of-the-box. These are paired with Bluetooth 5 support to offer high performance and compatibility with the latest Bluetooth devices.
64-bit performance
The NXP i.MX 8M Plus SoC comes with up to four powerful, 64-bit Armv8 Cortex-A53 cores, making them a cost-effective choice for running Linux with a modern graphical user interface while providing sufficient power reserves for typical industrial and medical applications.
The Toradex Verdin Family of Computer Modules
The Verdin iMX8M Plus is pin-compatible with the other CoMs in the Verdin family. This allows existing Verdin-based products to easily scale and migrate to the new Verdin iMX8M Plus. All of Toradex’s Verdin carrier boards are compatible with the Verdin iMX8M Plus. Extensive product documentation, developer support, service partners and third-party carrier boards are the pillars of our strong Verdin ecosystem.
운영 체제
Toradex offers free support and maintenance for Embedded Linux and FreeRTOS on the NXP i.MX 8M Plus processor based Verdin iMX8M Plus SoMs. This allows system designers to focus on the application only, instead of focusing also on the OS and low-level device drivers. Other OS' such as Android and QNX are supported by our partners.
Torizon Embedded Linux OS
FreeRTOS
Android
Android is supported by our service partner Kynetics. An Evaluation will be provided free-of-charge as a binary installer directly on the Toradex Easy Installer feeds.
QNX
QNX is a microkernel-based real-time operating system, primarily targeting embedded systems requiring high safety and security. An evaluation image is provided for Verdin iMX8M Plus directly from BlackBerry/QNX.
특징
High speed dual-band Wi-Fi
802.11ac 2x2 MU-MIMO
Bluetooth 5
Up to quad Arm Cortex -A53 @ 1.8 GHz
Single Arm Cortex M7F @ 800MHz
Vivante GC7000 UltraLite 3D GPU
Neural Processing Unit (NPU) - up to 2.3 TOPS
Up to 8GB LPDDR4 (32 bit)
Power Management IC (PMIC)
Industrial-grade flash memory – Up to 32GB eMMC
Gigabit Ethernet Transceiver
앞면
뒷면
CPU Name NXP® i.MX 8M Plus
CPU Type 4x Arm Cortex™-A53
Microcontroller 1x Arm Cortex™-M7F
CPU Clock 1.6 GHz (A53)
800 MHz (M7F)
Floating Point Unit VFPv4
NEON Yes
L1 Instruction Cache 32KB (A53)
32KB (M7F)
L1 Data Cache 32KB (A53)
32KB (M7F)
L2 Cache 512KB
RAM Up to 8GB LPDDR4 (32 bit)
Flash Up to 32GB eMMC
USB 3.1 1x Host / 1x OTG (Gen 1)
USB 2.0 1x Host / 1x OTG
Ethernet Gigabit with TSN (+2nd RGMII)
Wi-Fi 2.4/5 GHz Dual Band 2x2 Wi-Fi 5 (802.11ac)
Bluetooth Bluetooth 5.3
PCIe 1 (x1 Gen 3)
I2C 5x
SPI 3x
QSPI 1x
UART 4x
PWM 4x
GPIO 95x
Analog Input 4x
SDIO/SD/MMC 1x
CAN 2x (CAN FD)
JTAG 1x
Neural Processing Unit (NPU) Yes (2.3 TOPS)
Image Signal Processor (ISP) Yes
Display Controller Triple
Graphics Controller 2D: Vivante GC520L
3D: Vivante GC7000UL
Video Decoder Yes
Video Encoder Yes
Display Serial Interface 1x Quad Lane MIPI DSI (up to 1920x1080)
LVDS 1x (up to 1920x1080)
Digital Audio 6x SAI: I2S or AC97
S/PDIF In / Out 1x / 1x
2D Acceleration Yes
3D Acceleration Yes
HDMI 1x (2.0a, up to 4K)
Camera Serial Interface 2x Quad Lane MIPI CSI-2
Size 69.6 x 35.00 x 6.0 mm
Temperature -40° to +85° C(1)
Power Dissipation Approx. 1.5W - 6.3W
Product Availability 2036+
최적의 SoM을 선택하는 데 도와주세요
안내해주세요
다량 구매 가격 시작 US$51.90
대량 견적 받기
Verdin iMX8M Plus 구성하기
출발해요
최소한 다량 구매
from US$51.90
Verdin iMX8M Plus
Quad 8GB Wi-Fi / Bluetooth IT
PN: 0070
Verdin iMX8M Plus Quad 8GB Wi-Fi / Bluetooth IT
  • A53
  • A53
  • A53
  • A53
  • M7
  • 3D GPU
  • NPU
  • ISP
  • VPU
  • 8GB RAM
  • 32GB FLASH
  • -40° to +85° C
Verdin iMX8M Plus
Quad 4GB Wi-Fi / Bluetooth IT
PN: 0058
Verdin iMX8M Plus Quad 4GB Wi-Fi / Bluetooth IT
  • A53
  • A53
  • A53
  • A53
  • M7
  • 3D GPU
  • NPU
  • ISP
  • VPU
  • 4GB RAM
  • 32GB FLASH
  • -40° to +85° C
Verdin iMX8M Plus
Quad 4GB IT
PN: 0063
Verdin iMX8M Plus Quad 4GB IT
  • A53
  • A53
  • A53
  • A53
  • M7
  • 3D GPU
  • NPU
  • ISP
  • VPU
  • 4GB RAM
  • 32GB FLASH
  • -40° to +85° C
Verdin iMX8M Plus
Quad 2GB Wi-Fi / Bluetooth IT
PN: 0064
Verdin iMX8M Plus Quad 2GB Wi-Fi / Bluetooth IT
  • A53
  • A53
  • A53
  • A53
  • M7
  • 3D GPU
  • ISP
  • VPU
  • 2GB RAM
  • 16GB FLASH
  • -40° to +85° C
Verdin iMX8M Plus
QuadLite 1GB IT
PN: 0065
Verdin iMX8M Plus QuadLite 1GB IT
  • A53
  • A53
  • A53
  • A53
  • M7
  • 3D GPU
  • 1GB RAM
  • 8GB FLASH
  • -40° to +85° C
자신의 Verdin iMX8M Plus 구성하기
Verdin iMX8M Plus
4x Arm Cortex™-A53
1x Arm Cortex™-M7F
안내해주세요
Get Started
Verdin iMX8M Plus Evaluation Kit
US$736.60
  • Up to four Cortex-A53 1.8 GHz processors
  • Cortex-M7 processor with speeds up to 800 MHz
  • Neural Processing Unit (NPU)
  • Image Signal Processor (ISP)
  • NXP i.MX 8M Plus applications processor
  • Dual Band 2.4/5 GHz 2x2 Wi-Fi 5 (802.11ac) + Bluetooth 5.3
지금 구매
Verdin iMX8M Plus Evaluation Kit 2
US$435.60
지금 구매
캐리어 보드
SBC와 캐리어 보드에 대해 자세히 알아보기
Supported Modules
USB 3.0
USB 2.0
USB 2.0 Debug
Ethernet
PCIe
I2C
SPI
QSPI
UART
PWM
GPIO
Analog Input
RS232
RS485
SDIO/SD/MMC
CAN
Type-specific Extension Connector
JTAG
Low-speed Extension Connector
2x USB-A (Host)
1x USB-C (DualRole)
1x USB-C
2x Gigabit
1x (Mini PCIe)
4x
1x
1x
4x
3x
Up to 98x
4x
1x
1x
1x 4 Bit (Full Size)
2x
Yes
Yes
2x USB-A (Host)
1x USB-C (DualRole)
1x USB-C
1x Gigabit
1x (Mini PCIe)
3x
1x
1x
4x
3x
Up to 47x
4x
1x 4 Bit (microSD)
1x
Yes
1x USB-A (Host)
1x USB-A (Host), 1x USB-C (DualRole)
1x USB-C
1x Gigabit
1x (Mini PCIe)
2x
1x
4x
2x
31x
4x
1x 4 Bit (microSD)
1x Via transceiver / 1x On extension connector
Yes
2x
Entire Verdin Family
2x Host
1x USB-C (DualRole)
Gigabit
1x M.2 (Key B)
4x
1x
4x (1.8V levels)
2x
Up to 40x
4x
1x 4 Bit (microSD)
2x (without transceivers)
2x
2x Host
1x OTG
2x Gigabit
1x (Mini PCIe)
1x (extension connector)
1x RS232
1x RS485
2x isolated digital inputs
4x isolated digital outputs (photo relays)
2x Analog Input
0-25mA
1x 4 Bit (microSD)
2x (with transceivers)
up to 4x Host
up to 2x 10/100 MBit
1x
1x
1x RS-422, 1x RS-485
up to 4x
up to 24x
up to 4x
1x
Up to 2x
LEDs
4x
1x RGB: power on and status
2x RGB: user configurable
LVDS
HDMI
Digital Audio
VGA
RGB
Capacitive Touch Interface
Resistive Touch
Analog Audio Line in
Analog Audio Mic in
Analog Audio Headphone out
1x (via optional Verdin DSI to LVDS Adapter)
1x Native / 1x Via included Verdin DSI to HDMI Adapter
1x I2S
1x Quad Lane MIPI CSI-2
1x (Stereo)
1x (Stereo)
1x (Stereo)
1x (Stereo)
1x (Mono)
1x (Stereo)
1x Native / 1x Converted from the Verdin MIPI DSI interface
1x I2S
1x Dual Channel
1x
1x I2S
Yes
Yes
1x
1x
1x
1x
up to 4/5-wire
1x (Stereo)
1x (Mono)
1x (Stereo)
RTC on Board
TPM
1x (CR1025)
1x TPM2.0
Yes
1x (CR1025)
1x TPM2.0
Yes
1x
Supply Voltage
On-Board Power Supplies
Size
Temperature
7-24V DC ±10%
250mm x 200mm
0° to 70° C
5-24V DC ±10% or USB-C (PD and BC)
120mm x 120mm
0° to 70° C
8-25V DC ±10%
120mm x 120mm
0° to 60° C
7-24V DC ±10%
5V 6A
3.3V 7A
1.8V 2A
100 x 72 mm (Pico-ITX)
-25° to 85° C
8-72V
125 x 90 mm
-40°C to 85° C
5-36V DC
-40° to 85° C
사용 목적
가격
For Evaluation/Development
1 : US$322.40
1 : US$182.80
1 : US$198.90
For End Products
1-99 : US$107.50
>99 : RFQ
For End Products
액세서리
개발자 센터에서 자세히 알아보기
Verdin Industrial Heatsink Type 1
  • Compatible with Verdin iMX8M Mini, iMX8M Plus and AM62
  • 4 screws (M2x10mm) included with each heatsink for easy mounting to Verdin Carrier Boards
  • 34 Pins 0.5mm FFC Ribbon Cable (250mm) to connect with a Carrier Board
  • Cable length: 100mm
  • Manufacturer: Unictron
  • Manufacturer: Chang Hong
  • Reference: DA-2458-02
Pigtail Antenna Cable MHF4 to RP-SMA 100mm and 200mm
  • Cable length: 200mm
  • Suitable for outdoor-usage (IP67)
Verdin iMX8M Plus Mezzanine
  • USB 3.0: 1x USB-A (Host)
  • LVDS: 1x Dual Channel
CSI Camera Set 5MP Color AR0521
  • MIPI CSI-2 interface
  • onsemi AR0521 1/2.5" 5MP color image sensor with ISP
  • M12 lens mount (S-mount)
Videos
Verdin iMX8M Plus - Introduction
Development and Maintenance of your Embedded Linux Vision System – Simplified!
생태계
To get your products to market fast, with low risk and low engineering costs, you need more than just a System on Module with a stable operating system or BSP. We understand this, which is why we at Toradex are collaborating with a wide range of partners to make your life easier. Here are a few highlights. To find more, browse our Developer Page and take a look at our Partner Network.
Machine Learning and Computer Vision
Camera Module
Vision Components provides a large selection on camera modules, which can take advantage of the integrate Image Signal Processor (ISP) of the i.MX 8M Plus. A close collaboration allows a simple integration.
Camera Module
Several e-con Systems cameras are tested and ready-to-use out-of-the-box.
Get Started with e-con Systems
eIQ DeepView™
eIQ DeepView™ simplifies the optimization of machine learning algorithms for the edge, taking advantage of the Verdin iMX8M Plus’ NPU.
Get Started
Engineering Services
Antmicro and Toradex have collaborated on several projects in the past. Antmicro has deep knowledge in machine learning and computer vision and can accelerate even complex projects.
Learn More
Modular AI Vision Kit
Modular Vision Kit with Advanced AI hardware acceleration to streamline your development from prototype to production
Sony Camera Modules by Vision Components
Compact Carrier Board with Modular Connectivity
Enclosure
Torizon with OTA capabilities
Fully integrated with eIQ DeepView by Au-Zone
Rich, Intuitive Graphical User Interfaces
The Verdin iMX8M Plus provides high-performance graphics. Toradex partners closely with leading GUI technology providers to simplify the development process and make sure that hardware resources are utilized effectively.
Qt Framework
Get started with Qt On Demand Webinar: Kickstart your Qt Project on NXP i.MX 8
Crank Storyboard
Get started with Crank Storyboard
TotalCross
Get started with Totalcross
Industrial Automation
CODESYS PLC IEC 61131-3
The Verdin iMX8M Plus is a robust SoM, and its high performance is ideal for demanding industrial automation scenarios. CODESYS allows you to develop easily customized PLCs powered by a proven, long-lived software solution.
Get started with CODESYS on Torizon
Matrikon OPC UA
OPC UA is a standard technology widely used in industrial automation. The stack from Matrikon is a reliable, secure and platform-independent implementation that suits the Verdin iMX8M Plus perfectly. You can integrate it yourself, or leverage the expertise of our partner, BE.services, to outsource integration.
Watch our webinar with BE.services
(Coming Soon)
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your Verdin iMX8M Plus and choose an OS!
Learn More
로드맵
Min. Product Commitment
As per NXP Roadmap
2036+
Hardware Roadmap
For more details about PID8 level changes and historical releases please refer to the developer page.
  • Q2'24
  • Q3'24
  • Q4'24
  • Q1'25
  • Q2'25
0070 Verdin iMX8M Plus Quad 8GB WB IT
0058 Verdin iMX8M Plus Quad 4GB WB IT
0063 Verdin iMX8M Plus Quad 4GB IT
0064 Verdin iMX8M Plus Quad 2GB WB IT
0065 Verdin iMX8M Plus QuadLite 1GB IT
  • In Development
  • Early access product
  • Sample Production
  • Volume Product Candidate
  • Volume Production
Software Support Status
For latest news release refer
Linux BSP | Torizon OS BSP
Have a Question?
