NXP® i.MX 8QXP Computer on Module
Colibri iMX8X
- Up to 4x Arm® Cortex-A35 cores and 1x Cortex-M4 core
- NXP® i.MX 8QuadXPlus (i.MX 8QXP), i.MX 8DualXPlus (i.MX 8DXP), i.MX 8DualX (i.MX 8DX)
- Advanced hardware security and safety features
- Free OTA Update Solution
- Linux OS Support included
하이라이트
Up to four Cortex-A35 applications cores — the most power-efficient application Arm processor to support 32- and 64-bit code execution.
ECC (Error Correction Code) memory increases the reliability and safety of the system. The Colibri IMX8X has ECC-protected internal memory (TCM) in the SoC and CPU Caches. The internal memory is tightly coupled (TCM) with the Cortex-M4 core to provide a protected environment for software running the M4 microcontroller.
The heterogeneous multicore architecture allows the offloading of critical hard real-time tasks to the Cortex-M4F processors for extremely low latency. Toradex provides tooling and FreeRTOS to simplify development. You can also use the asymmetric multicore architecture for a connected low power mode or to increase security.
Simplify your design with pre-certified wireless options, counting from the module to the antennas, to increase the predictability of end-device certification processes while enabling significant cost savings. The latest 802.11ac standard and support for multi-antenna setups contribute to a great out-of-the-box end-user experience. These are paired with Bluetooth 5 support to offer state-of-the-art integration for Bluetooth devices.
Each module comes with environmental test reports for vibration and EMI/EMC to give you peace of mind. These modules are built with highly reliable eMMC flash memory, and tools like the Toradex Flash Analytics tool allow you to monitor flash wear in a simple manner.
Carrier boards designed for the Colibri iMX8X are not just compatible between the four Colibri iMX8X modules — in fact, they are compatible with the complete Colibri family, including the NXP i.MX 7, i.MX 6ULL, i.MX 6 and NVIDIA Tegra-based modules. This gives you unmatched flexibility and easy upgradability. Currently, there are eight different modules with over 20 variations available. To make carrier board design as easy as possible, we provide the Toradex Pinout Designer Tool.
운영 체제
Toradex offers free support and maintenance for embedded Linux and FreeRTOS on the NXP i.MX 8X-based Colibri iMX8X SoMs. This allows system designers to focus on the application only, instead of focusing also on the OS and low-level device drivers. Other OS such as Android are supported by ourpartners.
Toradex provides direct support for FreeRTOS on Colibri iMX8X and Colibri. FreeRTOS is a real-time OS that runs on the Cortex-M4 cores in parallel to the main OS.
Android on Colibri iMX8X is supported by our service partner Kynetics. An evaluation BSP is provided free of charge as a binary installer directly on Toradex Easy Installer feeds.
특징
CPU Name | NXP® i.MX 8X |
CPU Type | 4x Arm® Cortex™-A35 |
Microcontroller | 1x Arm® Cortex™-M4F |
CPU Clock | Up to 1.2 GHz (A35) 266 MHz (M4F) |
Floating Point Unit | VFPv4 |
Arm® NEON™ | Yes |
L1 Instruction Cache | 32KB (A35) 16KB (M4F) |
L1 Data Cache | 32KB (A35) 16KB (M4F) |
L2 Cache | 512KB (A35) |
Flash | Up to 8GB eMMC |
USB 2.0 | 1x Host / 1x OTG |
Ethernet | 10/100 MBit/s with AVB (+2nd RGMII/RMII) |
I2C | 8x |
SPI | 3x |
QSPI | 2x |
UART | 5x |
PWM | 10x |
GPIO | 97x |
Analog Input | 4x |
SDIO/SD/MMC | 1x |
CAN | 3x |
Display Controller | Single |
Graphics Controller | Vivante GC7000Lite |
Resistive Touch | 1x (4-wire) |
Parallel RGB LCD | 1x (up to 1280 x 720 x 24bpp) |
LVDS | 2x single channel 85 Mpixel/s or 1x dual channel 170 Mpixel/s Up to 1920x1200x24bpp at 60fps (via on-module FFC connector) |
Display Serial Interface | 2x quad-lane MIPI/DSI (via on-module FFC connector) |
Digital Audio | 4x SAI: I2S or AC97 |
Analog Audio Mic in | 1x (Mono) |
Parallel Camera Interface | 1x (up to 10 bits) |
Size | 67.6 x 36.7 x 6.2 mm |
Temperature | -40° to 85° C(1) |
Power Dissipation | TBD |
Colibri iMX8 QuadXPlus
2GB Wi-Fi / Bluetooth ITPN: 0038
A35
A35
A35
A35
M4F
3D GPU
VPU
2GB RAM
8GB FLASH
-40° to 85° C
2GB ITPN: 0050
A35
A35
A35
A35
M4F
3D GPU
VPU
2GB RAM
8GB FLASH
-40° to 85° C
Colibri iMX8 DualX
1GB Wi-Fi / BluetoothPN: 0051
A35
A35
M4F
3D GPU
VPU
1GB RAM
4GB FLASH
-25° to 85° C
최적의 SoM을 선택하는 데 도와주세요
안내해주세요Get Started
Colibri iMX8X Evaluation Kit
US$613.65
- Four Cortex-A35 1.2 GHz processor
- NXP i.MX 8X applications processor
- Parallel RGB or VGA (via converter) up to 1280 x 720 x 24bpp
Colibri iMX8X Evaluation Kit 2
US$434.65
- Parallel RGB or VGA VGA (via converter) up to 1280 x 720 x 24bpp
- Arduino Uno and Raspberry Pi Compatible Pin Headers
캐리어 보드
SBC와 캐리어 보드에 대해 자세히 알아보기액세서리
- No special drivers required
- Atmel touch driver
- Cable length: 100mm
- Manufacturer: Unictron
- Manufacturer: Chang Hong
- Reference: DA-2458-02
- Cable length: 200mm
- Connects directly to the HDMI FFC receptacle of the Colibri Evaluation Board, Iris or the Colibri HDMI Adapter
생태계
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your on Colibri iMX8X and choose an OS!
The Colibri iMX8X provides high-performance graphics. Toradex partners closely with leading GUI technology providers to simplify the development process and make sure that hardware resources are utilized effectively.
Qt Framework
Get started with Crank StoryboardDiSTI GL Studio
The Colibri iMX8X is ideal for critical applications where safety and reliability are key. These are also the key focus areas for DiSTI’s GL Studio.
Get started with DiSTI GL StudioEdge Computing
AWS IoT Greengrass
AWS provides a wide range of services to help you build scalable industrial IoT solutions. AWS IoT Greengrass is a key tool that runs directly on the Toradex SoM. Currently AWS, NXP and Toradex collaborate closely.
Get started with AWS SageMaker NeoIndustrial Automation
CODESYS PLC IEC 61131-3
The Colibri iMX8X is a robust SoM, and its high performance is ideal for demanding industrial automation scenarios. CODESYS allows you to develop easily customized PLCs powered by a proven, long-lived software solution.
OPC UA is a standard technology widely used in industrial automation. The stack from Matrikon is a reliable, secure and platform-independent implementation that suits the Colibri iMX8X perfectly. You can integrate it yourself, or leverage the expertise of our partner, BE.services, to outsource integration.
Watch our webinar with BE.services로드맵
Hardware Roadmap
- 2024
- 2025
- 2026
- 2027
- 2028
- 2029
- 2030
- In Development
- Sample Production
- Volume Production
Software Support Status
