Colibri T30
The Colibri T30 is a SODIMM sized computer module based on the NVIDIA© Tegra 3 embedded System-on-Chip. The Cortex A9 quad-core CPU peaks at 1.4 GHz. The module delivers very high CPU and graphic performance with minimum power consumption. The module comes with a pre-installed and fully licensed Windows Embedded Compact 7 core OS. Linux and Android are also available.
Colibri T30
The Colibri T30 product group is end-of-life (EOL). For further details please check the revision history of the product and the related PCN. Customers using end-of-life (EOL) Tegra products are advised to use our migration guide to seamlessly migrate to recommended hardware and software solutions for their products.
For a direct replacement, Toradex recommends the
Colibri iMX6, Colibri iMX8 product group or a transition to the Verdin product family.
하이라이트
Powered by NVIDIA: Tegra 3 Quad Core Processor
The Colibri T30 is a SODIMM sized computer module based on the NVIDIA© Tegra 3 embedded system-on-a-chip. The Cortex A9 quad core CPU peaks at 1.4 GHz. The module delivers very high CPU and graphic performance with minimum power consumption.
Designed in Switzerland. Made in Germany.
The Colibri T30 incorporates DVFS (Dynamic Voltage and Frequency Switching) and Thermal Throttling which enables the system to continuously adjust operation frequency and voltage in response to changes in workload and temperature to get the best performance with the lowest power.
The integrated NVIDIA Graphics enables visually rich, smooth and fast user interfaces.
Supreme Graphics Performance for Demanding Applications
The module targets a wide range of applications, including: Digital Signage, Medical Devices, Navigation, Industrial Automation, HMIs, Avionics, Entertainment System, POS, Data Acquisition, Thin Clients, Robotics, Gaming and much more
It offers a wide range of interfaces from simple GPIOs, industry standard I2C and SPI buses through to high speed USB 2.0 interfaces and a high speed memory bus. The HDMI interface makes it very easy to connect large, full HD resolution displays.
Easy Performance Upgrade
Existing customers will benefit from an extremely easy migration path from the current Colibri PXAxxx or Colibri T20 module range to the Colibri T30 – all Colibri modules are electrically pin compatible. New customers will also appreciate the ability to select the Colibri module most suitable for their application to achieve the optimum price/performance balance without the need to support different carrier board designs.
Latest Information on Colibri T30
You can find the latest information on Colibri T30 at the Toradex Developer Center
운영 체제
Toradex offers free support and maintenance for Windows Embedded Compact and Embedded Linux on the NVIDIA Tegra 3 processor based Colibri and Apalis T30 SoMs. This allows system designers to focus the application only instead of focusing on the OS and low-level device drivers. Other OS such as Android are supported by our partners.
Windows Embedded Compact 7 and 2013 are supported on both Colibri and Apalis T30. The development and maintenance is carried out in-house by Toradex. WEC allows you to use Microsoft .Net Compact Framework and Visual Studio.
Android
Android on Colibri and Apalis T30 is supported by our service partner Antmicro.
캐리어 보드
SBC와 캐리어 보드에 대해 자세히 알아보기
Colibri Evaluation Board
데이터 시트
Viola Carrier Board
Viola Datasheet
Colibri Partner Carrier Boards
Supported Modules
USB 2.0
Ethernet
External Bus
I2C
SPI
UART
IrDA
PWM
GPIO
Analog Input
SDIO/SD/MMC
CAN
JTAG
Entire Colibri Family
4x Host, 1x OTG/Client
10/100 Mbit
Up to 32 Bit
4x
4x
2x RS232, 1x RS422/485
1x
4x
up to 158
4x
1x 4 Bit
1x
Yes
1x Host / 1x OTG
10/100 Mbit
1x
1x
3x RS232
4x
up to 26
4x
1x 4 Bit (microSD)
2x Host, 1x Client (Shared)
10/100 Mbit
1x
1x
3x /
3x TTL
4x
up to 35
4x
1x 4 Bit (microSD)
10/100 Mbit
1x
1x
2x TTL, 1x USB-UART
4x
up to 39
4x
1x 4 Bit (SD/MMC)
Yes
up to 4x Host
up to 2x 10/100 MBit
1x
1x
1x RS-422, 1x RS-485
up to 4x
up to 24x
up to 4x
1x
Up to 2x
Switches
LEDs
6x
4x
up to 3x
LVDS
HDMI
VGA
RGB
Capacitive Touch Interface
Resistive Touch
Camera Parallel Interface
Analog Audio Line in
Analog Audio Mic in
Analog Audio Headphone out
1x Single Channel
1x (Through DVI-I connector)
1x
1x (18 Bit/24 Bit)
Adapter required
4/5-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
1x Dual Channel
1x (18 bit)
Yes
4/5-wire
1x (Stereo)
1x (Mono)
1x (Stereo)
1x (18 bit)
Adapter required
4-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
1x (Shared with RGB)
1x (18 bit)
Yes
4-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
1x
1x
1x
1x
up to 4/5-wire
1x (Stereo)
1x (Mono)
1x (Stereo)
Type Specific Board Connector
USB-to-RS232 Transceiver
RTC on Board
Included Accessory
1x
1x
Mating Power Plug (for X33)
24-way FFC 100mm (for X6)
Yes
1x
Mating Power Plug (for X17)
24-way FFC 35mm (for X4)
Yes
1x (*Not Assembled) /
1x
Yes
1x
1x
Yes
1x
Supply Voltage
On-Board Power Supplies
Size
Temperature
7-27V DC
5V 5A
3.3V 5A
200 x 200 mm
6-27V DC
5V 5A
3.3V 5A
100 x 72 mm
-20° to 85° C
5V DC +/- 5%
5V (External)
3.3V 3A
74 x 74 mm
-40° to 85° C
5V DC +/- 5%
3.3V 3A
100 x 80 mm
-25° to 85° C
5-36V DC
-40° to 85° C
사용 목적
가격
Minimum Product Commitment
For Evaluation/Development
1 : US$229.00
For End Products
1-99 : US$79.95
>99 : RFQ
2030
For End Products
1-99 : US$33.60
>99 : RFQ
2034+
1 : US$69.90
액세서리
개발자 센터에서 자세히 알아보기
Colibri Fasteners
Resistive Touch Display 7" Parallel
  • No special drivers required
Capacitive Touch Display 7" Parallel
  • Atmel touch driver
LM816 USB WiFi
Colibri HDMI Adapter
Analogue Camera Adapter
Carrier Board Accessory Kit
Have a Question?
