Colibri PXA320
Colibri PXA320 is an SODIMM sized computer module which is part of the Colibri product family. Colibri PXA320 is based on the Marvell Arm® XScale® PXA320 (Monahans) processor and runs at 806MHz. The processor's power consumption is optimized using the Intel Wireless Speedstep® Technology. The module comes with a pre-installed and fully licensed WinCE 5/6 core OS. Linux and Android are also available.
하이라이트
Ready for takeoff - Marvell XScale® PXA320 with 806MHz
The Colibri PXA320 is a SODIMM-sized computer module which is part of the Colibri family of modules. This product is used worldwide, in many critical applications. It comes with WinCE (Windows Embedded Compact) preinstalled. Its pin-compatibility with other Colibri modules featuring the latest SoCs from NVIDIA® and NXP® make it future-proof.
Colibri PXA320 is based on the Marvell Arm® XScale® PXA320 (Monahans) processor and runs at 806 MHz. The processor's power consumption is optimized using the Intel Wireless Speedstep® Technology.
Besides the internal Flash memory, there are plenty of interfaces available for data storage: USB-Memory Stick, Compact Flash / PCMCIA and SD Card.
Colibri modules provide glueless connectivity to passive and active LCDs with resolutions of up to 1024x768, as well as four and five-wire resistive touch screens. An integrated 16 bit stereo codec allows to play and record audio. Colibri modules can directly connect to a CMOS camera sensor.
In addition, these modules offer 100 MBit Ethernet as well as USB host and USB device functionality.
Pin-compatible with other Colibri modules
The Colibri family of modules are pin-compatible. This allows you to scale performance and price, and easily upgrade easily to the latest SoCs. Toradex WinCE (Windows Embedded Compact) OS and Toradex Software Libraries abstract the Hardware to make transition as easy as possible. To check if your carrier board is ready for your next Colibri module, use our quick and easy Pin-out Designer tool.
Design your own, use Toradex, or third-party Carrier Boards.
Industrial Temperature
Colibri PXA320 IT is a special version which meets the stringent requirement of industrial temperature range (-40 to +85 °C).
Professional development tools
Colibri modules come with a Windows CE operating system pre-installed. Also, state-of-the-art development tools allow easy customization of the system to make it fit specific needs (e.g. LCD settings & timings, integration of customer software and the auto-start option at startup).
Users can, therefore, concentrate on their actual application without going through the hassle of setting up an operating system. Special drivers are delivered by Toradex on request.
Latest Information on the Colibri PXA320
운영 체제
캐리어 보드
SBC와 캐리어 보드에 대해 자세히 알아보기액세서리
