하이라이트
Video Capabilities - Marvell XScale® PXA310 with 624MHz
Colibri PXA310 is an SODIMM sized computer module are part of the Colibri family of modules. It is in use worldwide in many critical applications. It comes preinstalled with WinCE (Windows Embedded Compact). Its pin-compatibility with other Colibri modules featuring the latest SoCs from NVIDIA® and NXP® make it future-proof.
The product targets cost-sensitive applications where connectivity and standard operating systems are essential. Colibri PXA310 is based on the Marvell XScale® PXA310 (Monahans) processor and runs at 624 MHz. It features hardware video encoding and decoding and offers an interesting operating temperature range from -20 to +85 °C. The processor's power consumption is optimized using the Intel Wireless Speedstep® Technology.
Besides the internal Flash memory, there are additional interfaces available for data storage: USB-Memory Stick and SD Card.
Colibri modules provide glueless connectivity to passive and active LCDs with resolutions of up to 1024x768. The modules can directly connect to a CMOS camera sensor.
In addition, Colibri modules offer 100 MBit Ethernet as well as USB host and USB device functionality.
Pin-compatible with other Colibri modules
The Colibri family of modules allows you to scale performance and price, and easily upgrade easily to the latest SoCs. Toradex WinCE (Windows Embedded Compact) OS and Toradex Software Libraries abstract the Hardware to make transition as easy as possible. To check if your carrier board is ready for your next Colibri module, use our quick and easy Pin-out Designer tool.
Design your own, use Toradex, or third-party Carrier Boards.
Professional development tools
Colibri modules come with a Windows CE operating system preinstalled and state-of-the-art development tools that allow for easy customization of the system to make it fit specific needs (e.g. LCD settings & timings, integration of customer software and the auto-start option at startup).
Latest Information on the Colibri PXA310
운영 체제
캐리어 보드
SBC와 캐리어 보드에 대해 자세히 알아보기액세서리
