NXP® i.MX 8 Computer on Module
Apalis iMX8
- Up to 2x Arm® Cortex-A72, 4x Cortex-A53, 2x Cortex-M4F
- NXP® i.MX 8QuadMax (i.MX 8QM), i.MX 8QuadPlus (i.MX 8QP)
- Advanced hardware security and safety features
- Integrated OTA Update Solution
- Linux OS Support included
하이라이트
The Apalis iMX8 is a small form factor system on module based on the latest NXP® i.MX 8 SoCs. The i.MX 8 SoC offering the best performance, the i.MX 8QuadMax, features two Cortex-A72 and four Cortex-A53 application processor cores, as well as two Cortex-M4F microcontroller cores with FPU. The modern Cortex-A cores support the Armv8 64-bit instruction set.
The Apalis iMX8 SoM is ideal for building cutting-edge computer vision systems. The high-performance dual GC7000 GPU supports feature-rich, complex graphical user interfaces with multiple independent displays. Toradex partners with the Qt Company, Crank Software and others to provide optimized UI frameworks, so you can get your product to market faster.
Support for hardware virtualization, Secure Boot and the latest cryptography ensure that you can build a safe and secure system. SafeAssure® fail-over-capable display controllers ensure that critical displays are always on and show valid content. The i.MX 8 SoCs are based on an advanced 28 nm FDSOI silicon process which increases MTBF and decreases soft error rates.
The heterogeneous multicore architecture allows the offloading of critical hard real-time tasks to the Cortex M4 or M7 processors for extremely low latency. Toradex provides tooling and FreeRTOS to simplify development. You can also use the asymmetric multicore architecture for a connected low power mode or to increase security.
Each module comes with environmental test reports for vibration and EMI/EMC to give you peace of mind. These modules are built with highly reliable eMMC flash memory, and tools like the Toradex Flash Analytics tool allow you to monitor flash wear in a simple manner.
The Apalis iMX8 is pin-compatible with the other CoMs in the Apalis family (*). This allows existing Apalis-based products to easily scale and migrate to the new Apalis iMX8. All of Toradex's Apalis Carrier Boards are compatible with the Apalis iMX8. Extensive product documentation, developer support, service partners and third-party carrier boards build our strong Apalis ecosystem.
(*) Visit our Apalis iMX8 Developer page to check full compatibility.
운영 체제
Toradex offers free support and maintenance for embedded Linux and FreeRTOS on the NXP i.MX 8-based Apalis iMX8 SoMs. This allows system designers to focus on the application only, instead of focusing also on the OS and low-level device drivers. Other OSs, such as Android and QNX, are supported by our partners.
Toradex provides direct support for FreeRTOS on Apalis iMX8 and Apalis. FreeRTOS is a real-time OS that runs on the Cortex-M4 cores in parallel to the main OS.
Android on Apalis iMX8 is supported by our service partner Kynetics. An evaluation BSP is provided free of charge as a binary installer directly on Toradex Easy Installer feeds.
QNX is a microkernel-based OS primarily targeting safety-critical embedded systems. An evaluation image is provided for Apalis iMX8 directly from BlackBerry/QNX.
특징
CPU Name | NXP i.MX 8QuadMax NXP i.MX 8QuadPlus |
CPU Type | Up to 2x Arm® Cortex-A72Up to 4x Arm® Cortex-A53Up to 2x Arm® Cortex-M4F |
CPU Clock | Up to 1.6 GHz (Arm® Cortex-A72)Up to 1.26 GHz (Arm® Cortex-A53)Up to 266 MHz (Arm® Cortex-M4F) |
Floating Point Unit | VFPv4 |
NEON MPE | Yes |
ARM TrustZone | Yes |
Advanced High Assurance Boot | Yes |
Cryptographic Acceleration and Assurance Module | Yes |
Secure Real-Time Clock | Yes |
Secure JTAG Controller | Yes |
Secure Non-Volatile Storage | Yes |
L1 Instruction Cache | 48 KB (A72) 32 KB (A53) 16 KB (M4F) |
L1 Data Cache | 32 KB (A72) 32KB (A53) 16KB (M4F) |
L2 Cache | 1 MB (A72) 1 MB (A53) |
Tightly-Coupled Memory (TCM) | 256 KB (M4F) |
RAM | Up to 8GB LPDDR4 |
Flash | Up to 32 GB eMMC |
Bluetooth | Bluetooth 5.3 |
PCIe | 2x 1 lane (Gen 3.0) |
I2C | Up to 7x |
SPI | Up to 4x |
UART | Up to 7x |
SD/SDIO/MMC | 2x |
GPIO | Up to 133x |
USB 2.0 | 2x Host / 1x OTG |
USB 3.0 | 1x Host |
Ethernet | 10/100/1000 Mbit with IEEE 1588 (+2nd RGMII) |
PWM | Up to 8x |
Analog Input | Up to 8x |
CAN/CAN-FD | Up to 3x |
JTAG | 1x |
LVDS | Up to 3x single channel Standard: 2x single channel 85 Mpxiel/s or 1x dual channel 170 Mpixel/s Non-standard: 1x single channel 85 Mpxiel/s |
HDMI | 2.0a 4K (3840x2160@60Hz) |
Display Serial Interface | 1x Single Lane MIPI DSI up to 1.5Gbps |
Camera Serial Interface | 2x Quad Lane MIPI CSI-2 |
Medium Quality Sound (MQS) | 1x (Stereo) |
Digital Audio | Serial Audio Interface (SAI): 3x AC97/I2S Enhanced Serial Audio Interface (ESAI): 1x AC97/I2S |
S/PDIF | 1 in and 1 out IEC 60958 32kHz to 192kHz sampling rates |
Size | 82.0 x 45.0 x 6.0 mm |
Temperature | -40° to 85° C |
Power Dissipation | Up to 14W |
Apalis iMX8 QuadMax
8GB Wi-Fi / Bluetooth ITPN: 0067
A72
A72
A53
A53
A53
A53
M4F
M4F
8GB RAM
32GB FLASH
GPU
GPU
VPU
-40° to 85° C
Apalis iMX8 QuadMax
4GB Wi-Fi / Bluetooth ITPN: 0037
A72
A72
A53
A53
A53
A53
M4F
M4F
4GB RAM
32GB FLASH
GPU
GPU
VPU
-40° to 85° C
Apalis iMX8 QuadMax
4GB ITPN: 0047
A72
A72
A53
A53
A53
A53
M4F
M4F
4GB RAM
32GB FLASH
GPU
GPU
VPU
-40° to 85° C
Apalis iMX8 QuadPlus
2GB Wi-Fi / BluetoothPN: 0048
A72
A53
A53
A53
A53
M4F
M4F
2GB RAM
32GB FLASH
GPU
GPU
VPU
-25° to 85° C
최적의 SoM을 선택하는 데 도와주세요
안내해주세요Get Started
Apalis iMX8 Evaluation Kit
US$1,035.65
- 2x Arm Cortex-A72 CPU cores
- 4x Arm Cortex-A53 CPU cores
- 2x Arm Cortex-M4F CPU cores
- NXP i.MX 8 applications processor
Apalis iMX8 Evaluation Kit 2
US$562.65
- 1x Arm Cortex-A72 CPU core
캐리어 보드
SBC와 캐리어 보드에 대해 자세히 알아보기액세서리
- Compatible with Apalis iMX8
- Cable length: 100mm
- Manufacturer: Unictron
- Manufacturer: Chang Hong
- Reference: DA-2458-02
- Cable length: 200mm
- MIPI CSI-2 interface
- M12 lens mount (S-mount)
생태계
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your on Apalis iMX8 and choose an OS!
Learn MoreRich, Intuitive Graphical User Interfaces
The Apalis iMX8 provides high-performance graphics. Toradex partners closely with leading GUI technology providers to simplify the development process and make sure that hardware resources are utilized effectively.
Qt Framework
Get started with Qt On Demand Webinar: Kickstart your Qt Project on NXP i.MX 8Crank Storyboard
Get started with Crank StoryboardDiSTI GL Studio
The Apalis iMX8 is ideal for critical applications where safety and reliability are key. These are also the key focus areas for DiSTI’s GL Studio.
Get started with DiSTI GL StudioTotalCross
Get started with TotalcrossAI at the Edge
The Apalis iMX8 has the highest performance of the i.MX 8 SoCs. Its multiple Armv8 64-bit cores and dual GPU make it an ideal platform for machine learning and computer vision applications.
Low latency and high reliability requirements are advantages fueling the growth of edge computing. Toradex collaborates with partners to offer its customers a simple way to take advantage of the latest technologies in AI, computer vision, and edge computing.
DeepView™ 2 Machine Learning Algorithm
DeepView™ 2 simplifies the optimization of the machine learning algorithm for the edge, taking advantage of the CPUs and GPUs in the Apalis iMX8.
Get updatesAWS IoT Greengrass and SageMaker Neo
AWS provides a wide range of services to help with AI at the edge, such as AWS IoT Greengrass and SageMaker Neo. Currently AWS, NXP and Toradex collaborate closely.
Get started with AWS SageMaker NeoAlvium Industrial-Grade MIPI CSI-2 Cameras
For vision applications, the new Alvium family of industrial-grade MIPI CSI-2 cameras is ideal. Learn more about integration with Toradex products in the Pasta Detection Demo for AI at the edge with AWS.
Apalis iMX8 Embedded Vision KitAntmicro Apalis Smart Vision Kit
Antmicro offers an off-the-shelf, dual-camera, MIPI CSI-2 carrier board, as well as hardware and software engineering services for the Apalis iMX8 as an extension of Toradex’s offerings.
Antmicro Vision kitIndustrial Automation
CODESYS PLC IEC 61131-3
The Apalis iMX8 is a robust SoM, and its high performance is ideal for demanding industrial automation scenarios. CODESYS allows you to develop easily customized PLCs powered by a proven, long-lived software solution.
OPC UA is a standard technology widely used in industrial automation. The stack from Matrikon is a reliable, secure and platform-independent implementation that suits the Apalis iMX8 perfectly.
Watch our webinar with BE.servicesHeterogeneous Multicore Processing (HMP) for Real Time, Safety and Low Power
The Apalis iMX8 comes with two Cortex-M4 cores clocked at a fast 266 MHz. These cores are ideal for offloading hard real-time applications from Linux, as the M4 allows for latencies measured in microseconds.
Other common use cases are active low power modes, where the main cores are switched off for functional safety while the M4 cores run an RTOS like SafeRTOS from the ECC-protected, tightly coupled memory inside the i.MX 8.
Toradex also invests in making the M4 core easily accessible to you, with developments such as Visual Studio Code integration.
Our long-term cooperation with Toradex has allowed us to develop a comprehensive and flexible code base that can easily be upgraded from the previous Apalis i.MX 6-based infotainment to the new i.MX 8-based one."
ICU Software Manager, Rimac Automobili d.o.o.
로드맵
Hardware Roadmap
- 2024
- 2025
- 2026
- 2027
- 2028
- 2029
- 2030
- In Development
- Sample Production
- Volume Production
Software Support Status
